pauljb12
Router connection issues
Sun May 15, 2022 11:16 pm
Hi All
I have a chateau 12 router which I had set up and working perfectly. A couple of days ago I had an issue with the wifi in that I lost the 2.4ghz band. I tried to turn it off and on again but whatever happened I must have turned off the 5ghz as well. I tried to reset the router but I still can not get a wifi signal.
It loads up and shows signal strength leds, the power led is blue. I have tried to connect an ethernet cable directly between the router and my mac but it can't seem to get an ip address (Self assigned) I can't seem to access 192.168.88.1 to try and manually restart the wifi / router.
I am using a mac and do not have access to a windows. Compared to others here my computer skills would be basic. I can use terminal with a step by step guide for example.
Thanks in advance.
Users browsing this forum: Amazon [Bot], complexxL9, d513, panzermaster18, Semrush [Bot] and 211 guests
