pcunite
Setting Queue Tree max-limit value
Sun May 15, 2022 11:44 pm
I need to change the max-limit value. I'm not sure how to debug scripts to see what is incorrect about this syntax. What is the error here? This should work. RouterOS v6.47.10
# Set QoS Values
:local sGateway "1.2.3.4"
:if ( $sGateway  = "1.2.3.4") do={
     :log info "Setting speed to 4.5M"
     /queue tree set [find name="DOWN"] max-limit=4500k]
    } else={
      :log info "Setting speed to 40M"
      /queue tree set [find name="DOWN"] max-limit=40M]
chechito
Re: Setting Queue Tree max-limit value
Mon May 16, 2022 12:36 am
you can save the script in /system scripts then you run the script from console with /system scripts run command then you will see the errors
rextended
Re: Setting Queue Tree max-limit value  [SOLVED]
Mon May 16, 2022 2:45 am
just too much ] at the end...
pcunite
Mon May 16, 2022 4:22 pm
Ugh ... thank you!
... run the script from console with /system scripts run command then you will see the errors ...
That's helpful, thank you!
Users browsing this forum: No registered users and 39 guests
