tartangeek
Port Forwarding issue
Mon May 16, 2022 9:28 am
Hi
I am trying to port forward to 2 ports, 1212 and 1250 so that a customers software will connect externally to the server on 192.168.1.64
The REALLY frustrating thing is I configured it and tested the ports and they worked but now won't.
I have spoken to the ISP and they are not blocking it at all. I amntearing my hair out so please help
Config attached
[admin@MikroTik] > export
# may/10/2022 16:20:40 by RouterOS 6.47.9
# software id = AH1F-487G
# model = RB760iGS
add admin-mac=DC:2C:6E:01:61:AE auto-mac=no \
    comment=defconf name=bridge
/interface vlan
add interface=ether1 name=ufb-vlan10 vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] supplicant-identity=\
    MikroTik
/ip hotspot profile
set [ find default=yes ] html-directory=\
    flash/hotspot
add name=dhcp ranges=192.168.1.10-192.168.1.200
add name=dhcp_pool1 ranges=\
    192.168.1.10-192.168.1.220
add address-pool=dhcp disabled=no interface=\
    bridge name=defconf
add bridge=bridge comment=defconf interface=\
    ether2
    ether3
    ether4
    ether5
add bridge=bridge comment=defconf interface=sfp1
add comment=defconf interface=ufb-vlan10 list=\
    WAN
add address=192.168.1.1/24 comment=defconf \
    interface=ether2 network=192.168.1.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=no interface=\
    ufb-vlan10
add address=192.168.1.0/24 comment=defconf \
    dns-server=103.212.xx.x,8.8.8.8 gateway=\
    192.168.1.1 netmask=24
/ip dns static
add address=192.168.1.1 comment=defconf name=\
    router.lan
/ip firewall address-list
add address=192.168.1.0/24 list=LAN
add address=103.212.xx.0/24 list=WAN
    "defconf: accept out ipsec policy" \
    ipsec-policy=out,ipsec
    "defconf: accept in ipsec policy" \
    ipsec-policy=in,ipsec
add action=accept chain=input comment="defconf: a\
    ccept established,related,untracked" \
    connection-state=\
add action=accept chain=forward \
    connection-state=established
    connection-nat-state=dstnat \
    connection-state=""
add action=accept chain=forward comment="defconf:\
    \_accept established,related, untracked" \
    connection-state=\
    "defconf: accept ICMP" protocol=icmp
    ccept to local loopback (for CAPsMAN)" \
    dst-address=127.0.0.1
add action=accept chain=input dst-port=8291 \
    protocol=tcp
add action=fasttrack-connection chain=forward \
    comment="defconf: fasttrack" \
    "defconf: drop invalid" connection-state=\
    invalid
    "defconf: drop all not coming from LAN" \
    in-interface-list=LAN
    invalid
    "defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat \
    "allow port forwarding" \
add action=masquerade chain=srcnat comment=\
    "defconf: masquerade" ipsec-policy=out,none \
    out-interface-list=WAN
add action=dst-nat chain=dstnat comment=\
    "Software allow from home" dst-port=1212 \
    in-interface-list=WAN protocol=tcp \
    to-addresses=192.168.1.64 to-ports=1212
    in-interface-list=WAN protocol=udp \
    "Software allow from home SSL" disabled=yes \
    dst-port=8443 in-interface-list=WAN \
    protocol=udp to-addresses=192.168.1.64 \
    to-ports=1212
    "Software allow from home" dst-port=1250 \
    to-addresses=192.168.1.64 to-ports=1250
    protocol=tcp to-addresses=192.168.1.64 \
    to-ports=1250
add action=dst-nat chain=dstnat disabled=yes \
    dst-address=139.5.166.151 to-addresses=\
    192.168.1.64
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.1.0/24
set ssh address=192.168.1.0/24
set www-ssl disabled=no
set api disabled=yes
set winbox address=192.168.1.0/24
set api-ssl disabled=yes
/system clock
set time-zone-name=Pacific/Auckland
/tool mac-server
/tool mac-server mac-winbox
Jotne
Re: Port Forwarding issue
Mon May 16, 2022 1:16 pm
Not an answer to your question, but
[*] never open opp 8192 from internet to admin your router. You asking for problems.
add action=accept chain=input dst-port=8291 protocol=tcp
See this post: viewtopic.php?p=870631#p870631
set winbox address=192.168.1.0/24 This helps some. Edit FW rule to only accept LAN
[*] Inside IP should be bound to bridge, not to an interface part of the bridge:
wrong
add address=192.168.1.1/24 comment=defconf interface=ether2 network=192.168.1.0
correct (same as you already has bound your DHCP server to)
add address=192.168.1.1/24 comment=defconf interface=bridge network=192.168.1.0
[*] Edit and remove serial number from your post, with that I found your ip to be 103.x.x.x3 du to cloud service, and with Winbox open, I can just start hacking.
[*] Nothing wrong but, to-ports are not needed in NAT if its the same as dst-port
To test your NAT (tcp part) visit https://canyouseeme.org/ and type in port 1212
anav
Mon May 16, 2022 2:46 pm
YOu need to organize your firewall rules better so input and forward chain rules are not intermingled.
As well you have some mess, duplicates in the forward chain that need to be cleaned up including the order of rules.
Its clear you dont have a clue of what the rules are actually saying/doing and thus more important than port forwarding is learning about the config.
Sob
Tue May 17, 2022 2:08 am
As long as ISP really isn't blocking anything and you're testing it from internet (not from LAN), it should work. If you look at dstnat rules' counters, do they get any hits when you test those ports?
tartangeek
Wed May 18, 2022 2:54 am
Yes that is the strange thing as the counters do move but then it stops there. I have checked that the Firewall on the server is allowing those ports and it does so am lost.
Sob
Wed May 18, 2022 3:37 am
Keep looking at server, because router doesn't block it. You can try to add e.g.:
/ip firewall mangle
add chain=postrouting dst-address=192.168.1.64 protocol=tcp dst-port=1212 action=log log-prefix="request"
add chain=prerouting src-address=192.168.1.64 protocol=tcp src-port=1212 action=log log-prefix="response"
You should see some requests logged, but responses will probably be tcp resets or none at all.
tartangeek
Wed May 18, 2022 4:35 am
yeah after tidying up everything and firewall rules etc it still does not work yet it gets packets when you try to telnet to it. Must be on server. Thanks all for your help
Jotne
Wed May 18, 2022 8:51 am
Remove the router, setup a linux pc where you change ssh port from 22 to 1212. Connect it to your IPS and test it you can reach that from internet.
If yes, some is wrong with RouterOS config, if no, ISP problems.
Users browsing this forum: No registered users and 28 guests
