elmertronics
Email from/to Gmail Only
Tue May 17, 2022 8:56 am
Hi all. I want to run an email server behind the mikrotik router. I want to receive and send emails from/to Gmail only. How can I implement this to mikrotik router? Thank you.
rextended
Re: Email from/to Gmail Only
Tue May 17, 2022 10:01 am
To choose which remote servers / clients to accept, this concerns the mail server configuration, not the RouterBOARD.
To "guess" if you need NAT or just a firewall filter, you have to specify the parameters of the RouterBOARD and the Server.
First of all, clarify what you want and ask a more specific question by providing all the necessary details.
The less details you write, the less help you get.
SiB
Tue May 17, 2022 10:36 am
elmertronics:
Use Firewall DNAT to forward traffic to your MTA.
SNAT to be sure MTA will out the same IP what you use in DNAT.
on MTA use some whitelist on gmail.com and block others.
You can try filter on Firewall the IP from Gmail servers too.
Larsa
Tue May 17, 2022 10:48 am
As @rextended explained this has very little to do with Mikrotik as such (just a few of filters needed for that). To succeed with relaying using smtp on google mail servers you need a public ip, mx-domain and proper setup of spf/dkim/dimarc (arc) which google is very picky about before any email is let through.
Besides the need for a Corporate or Google Workspace account to setup spf for your domain you have to hijack outbound port 25 to always point to smtp-relay.gmail.com and the other way around to allow only inbound smtp from google. There are plenty of help pages from Google regarding this like: https://support.google.com/a/answer/2956491?hl=en
Users browsing this forum: Google [Bot], sid5632 and 170 guests
