lurch
isp pppoe with dslam
Tue May 17, 2022 12:50 pm
I've done some googling but can't find anything which matches my requirements. Basically I need to setup the following
ISP Modem which requires specific username/password and vlan > DSLAM to terminate the connection via rj11 > Miktrotik ethernet connected to modem
So the modem will sync with dslam, modem lan port will be connected to port 20 on the mikrotik which will need to connected using the isp username/password/vlan. Finally a PC connected to port 21 should be able to use the connection on port 20 without any further configuration.
Does anyone know of a guide/sample config that would allow me to do this?
Users browsing this forum: Ahrefs [Bot], bdivrik, CodeAlpha, K0NCTANT1N, nonolk, Techsystem and 127 guests
