sirnef
Lost "Management VLAN" access to switches
Tue May 17, 2022 6:19 pm
I am trying to configure VLANs on a network. Currently the network diagram looks as follows:
On the CRS326 switches, I have this configuration for VLANs:
switch1:
/system identity
set name=switch1
add name=BR1 protocol-mode=none
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] disabled=yes
set [ find default-name=ether10 ] disabled=yes
set [ find default-name=ether11 ] disabled=yes
set [ find default-name=ether12 ] disabled=yes
set [ find default-name=ether13 ] disabled=yes
set [ find default-name=ether14 ] disabled=yes
set [ find default-name=ether15 ] disabled=yes
set [ find default-name=ether16 ] disabled=yes
set [ find default-name=ether17 ] disabled=yes
set [ find default-name=ether18 ] disabled=yes
set [ find default-name=ether19 ] disabled=yes
set [ find default-name=ether20 ] disabled=yes
set [ find default-name=ether21 ] disabled=yes
set [ find default-name=sfp-sfpplus1 ] disabled=yes
set [ find default-name=sfp-sfpplus2 ] disabled=yes
add bridge=BR1 interface=ether1 pvid=10
add bridge=BR1 interface=ether2 pvid=30
add bridge=BR1 interface=ether3 pvid=50
add bridge=BR1 interface=ether22
add bridge=BR1 interface=ether23
add bridge=BR1 interface=ether24
/interface bridge vlan
add bridge=BR1 tagged=ether24,ether22,ether23 untagged=ether1 vlan-ids=10
add bridge=BR1 tagged=ether24,ether22,ether23 untagged=ether2 vlan-ids=30
add bridge=BR1 tagged=ether24,ether22,ether23 untagged=ether3 vlan-ids=50
add bridge=BR1 tagged=BR1,ether24,ether22,ether23 vlan-ids=99
add address=192.168.99.2/24 interface=VLAN_99_MANAGEMENT network=192.168.99.0
/tool romon
set enabled=yes
/interface bridge set BR1 vlan-filtering=yes
switch2:
/system identity
set name=switch2
set [ find default-name=ether2 ] disabled=yes
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether22 ] disabled=yes
set [ find default-name=ether23 ] disabled=yes
/interface vlan
add interface=BR1 name=VLAN_99_MANAGEMENT vlan-id=99
add bridge=BR1 tagged=ether24 untagged=ether1 vlan-ids=10
add bridge=BR1 tagged=BR1,ether24 vlan-ids=99
add address=192.168.99.3/24 interface=VLAN_99_MANAGEMENT network=192.168.99.0
/tool romon
set enabled=yes
switch3:
/system identity
set name=switch3
/interface vlan
add address=192.168.99.4/24 interface=VLAN_99_MANAGEMENT network=192.168.99.0
/tool romon
set enabled=yes
My router is pfSense. There I have set up VLANs on the LAN interface:
Their addresses are:
The only problem for now is that from PC1 (VLAN10) I cannot access the switches. In fact, on pfSense I don't see the swiches visible in the ARP table at all. Winbox doesn't detect them for me either. It looks like they have no IP addresses set. Can you guys help? Additionally, I have no problem to connect from PC1 (192.168.10.2) to pfSense (192.168.99.1). For all VLANs I temporarily set up a firewall to pass all traffic for each protocol.
akakua
Re: Lost "Management VLAN" access to switches
Tue May 17, 2022 6:52 pm
Routes on switches?
Zacharias
Tue May 17, 2022 10:12 pm
They don't.
Your management VLAN is 99 and not VLAN 10.
For testing, set the PVID on the port of PC1 to 99, and then check again.. Do the switches have an IP now ?
sirnef
Re: Lost "Management VLAN" access to switches  [SOLVED]
Thu May 19, 2022 4:02 pm
@akakua @Zacharias I found it. I forgot:
/interface vlan
in my config for the first switch. Now I got access to all of them even when I 'm in the VLAN10, because as I said, I pass all the traffic between VLANs on the pfSense.
pe1chl
Thu May 19, 2022 4:08 pm
That makes your whole "Management VLAN" exercise a bit pointless, doesn't it?
sirnef
Thu May 19, 2022 4:44 pm
I tried to configure VLANs. In the next steps I plan to add rules to the firewall that will block most of the traffic.
I just don't know what approach makes the most sense:
1) leave one free port on the switch that handles my Management VLAN 99 and go through it and do the configuration if necessary
2) use firewall to allow traffic from one Admin host, which is in different VLAN, to VLAN99
3) or maybe some other solution is more reasonable?
pe1chl
Thu May 19, 2022 5:06 pm
It depends a bit on local policies and your requirements, there are people who believe that only a physically separate management network is good enough, and others that think that a separate VLAN is good.
But a management network that is routed to the main network is of course no extra value, unless you can limit that routing to e.g. another VLAN that has only a very limited number of workstations or "jump hosts".
Users browsing this forum: Ahrefs [Bot], simtj and 91 guests
