ajglowacki1
Host Can't Ping other Network But MikroTiks Can
Tue May 17, 2022 7:22 pm
I'm setting up a lab in for our Office. For some reason, hosts can't ping outside their network but the MikroTiks can. All MikroTik devices are using RouterOS 6.
Host is connected to ether1.
An Ubiquiti Device to ether24
MikroTik Devices to ether19 thru ether23.
Host is attempting to ping 10.50.50.0/24 network (10.50.50.1 and 10.50.50.198 specifically).
Host IP is 192.168.89.2/24 + GW 192.168.89.31
FULL CONFIG
[admin@MikroTik] > export
# may/17/2022 11:15:16 by RouterOS 6.46.1
# software id = KWDC-246G
# model = CRS125-24G-1S-2HnD
# serial number = 49C804C57629
add name="MGMT Bridge"
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge ssid=MikroTik-92289D wireless-protocol=802.11
set [ find default-name=ether1 ] comment="Maintenance Computer"
set [ find default-name=ether19 ] comment="MGMT 750GR 02"
set [ find default-name=ether20 ] comment="MGMT 750GR 01"
set [ find default-name=ether21 ] comment="MGMT 750GL 03"
set [ find default-name=ether22 ] comment="MGMT 750GL 02"
set [ find default-name=ether23 ] comment="MGMT 750GL 01"
set [ find default-name=ether24 ] comment="GATEWAY: DREAM MACHINE"
/interface vlan
add disabled=yes interface="MGMT Bridge" name="MGMT VLAN" vlan-id=99
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=no name=defconf
add bridge="MGMT Bridge" interface=ether23 trusted=yes
add bridge="MGMT Bridge" interface=ether22 trusted=yes
add bridge="MGMT Bridge" interface=ether21 trusted=yes
add bridge="MGMT Bridge" interface=ether20 trusted=yes
add bridge="MGMT Bridge" interface=ether1 trusted=yes
add bridge="MGMT Bridge" interface=ether24 trusted=yes
add comment=defconf list=LAN
add address=192.168.99.31/24 comment="MGMT VLAN" interface="MGMT VLAN" network=\
192.168.99.0
add address=192.168.89.31/24 comment="MGMT Bridge" interface="MGMT Bridge" \
network=192.168.89.0
/ip dhcp-client
# DHCP client can not run on slave interface!
add disabled=no interface=ether24
set allow-remote-requests=yes
/ip dns static
add action=accept chain=forward dst-address=0.0.0.0 in-interface="MGMT Bridge" \
out-interface="MGMT Bridge" src-address=0.0.0.0
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
established,related,untracked
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
dst-address-list=bad_ipv6
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
protocol=udp
ipsec-ah
ipsec-esp
/system clock
set time-zone-name=America/Chicago
/tool mac-server
/tool mac-server mac-winbox
ROUTES:
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 10.50.50.1 1
1 ADC 10.50.50.0/24 10.50.50.198 MGMT Bridge 0
2 ADC 192.168.89.0/24 192.168.89.31 MGMT Bridge 0
Sob
Re: Host Can't Ping other Network But MikroTiks Can  [SOLVED]
Wed May 18, 2022 2:52 am
You have masquerade rule with out-interface-list=WAN and ether1 in WAN list, but because ether1 is also bridge port, outgoing interface, as seen by IP firewall, is MGMT Bridge, so masquerade doesn't work. If upstream router doesn't have route to 192.168.89.2, the host has no chance to get out (more accurately, packets can get out, but no reponse will come back). The config is let's say a bit unusual.
Users browsing this forum: almdandi, Majestic-12 [Bot], RBrogen and 63 guests
