xr1s
DHCP assign static outside pool
Tue May 17, 2022 9:53 pm
Hi!
Can't find related info and my brain hasn't untangled the logic, but wondering if I can assign static leases/ips outside the dhcp server pool? (all inside same subnet)
ie, have x.x.x.200-x.x.x.250 /24 main pool. Want to set aside some devices to use x.x.x.180-x.x.x.199.
1- can I just set those static assignments with the addresses I want?
2- would I have to create a pool for those?
Would test, but I am remote in atm, don't wan to break anything.
Thanks!
EDIT: mod addresses.
Zacharias
Re: DHCP assign static outside pool
Tue May 17, 2022 9:57 pm
But those IPs you specify are not outside the main DHCP pool...
You can assign static leases to those devices... Let the DHCP assign an address to them, and then make it static and assign the IP you wish... On the Lease renew, the static IP will be assigned to the device...
xr1s
Tue May 17, 2022 10:17 pm
My bad, sorry, got addresses mixed up.
So main pool is from .200 to .250, statics I want to assign are .180 to .199
Thansk!
Zacharias
Tue May 17, 2022 10:19 pm
Create static leases...
xr1s
Tue May 17, 2022 10:39 pm
Thanks!
anav
Tue May 17, 2022 11:31 pm
Within the dhcp server leases in winbox, create the new lease + symbol, then add the ip address desired and mac address of the device manually, then SAVE it.
Then go back to the new lease on the list and you should see an OPTION to SET STATIC.
Users browsing this forum: GoogleOther [Bot], intania, Marc1963, sas2k, sch, vesuviustreamline and 203 guests
