chrisr865
PPPOE target
Wed May 18, 2022 8:28 am
Hi all,
I have a weird situation on one router 5009 with PPPOE server. Sometimes the target end up being weird characters, and when that happens in influence all the other users.
On winbox under queues it displays the target as <unknown>
Using a 5009, ROS 7.2.3
/interface pppoe-server server
add default-profile=PPPoE_Profile disabled=no interface=Guest-Bridge keepalive-timeout=disabled one-session-per-host=yes service-name=PPPOE
/ppp profile
add change-tcp-mss=yes dns-server=8.8.8.8,8.8.4.4 local-address=10.1.64.1 name=PPPoE_Profile only-one=yes remote-address=POOL-PPPOE-Paid use-compression=yes use-encryption=yes use-mpls=no use-upnp=no
add address=10.1.64.1/20 interface=Guest-Bridge network=10.1.64.0
thanks
chris
Zacharias
Re: PPPOE target
Wed May 18, 2022 4:56 pm
I think that is an indication of an unknown interface.
What did you set as target there? Maybe a dynamic interface ?
chrisr865
Re: PPPOE target
Wed May 18, 2022 5:46 pm
Hi Zacharias, thanks for the reply
Yes in the queue's it displays the target as <unknown>, but on the setup of the PPPOE server it is setup as a VLAN-interface
tx
chris
Zacharias
Re: PPPOE target
Wed May 18, 2022 8:16 pm
Does that VLAN interface exist ?
chrisr865
Re: PPPOE target
Wed May 18, 2022 9:25 pm
sorry lost you there
/interface vlan
add interface=ether8 name=Guest-Bridge vlan-id=4001
vlan
interfaces
tx
chris
chrisr865
Re: PPPOE target
Thu May 19, 2022 6:11 am
hey,
heres a pic of the queues
tx
chris
chrisr865
Re: PPPOE target
Thu May 19, 2022 7:47 pm
hi,
anyone knows what might cause this?
tx
chris
chrisr865
Re: PPPOE target
Fri May 20, 2022 5:05 pm
hey, just checking if anyone came across this issue before, and how did you solve it?
tx
chris
chrisr865
Re: PPPOE target
Mon May 30, 2022 6:45 am
hi there,
is it only me that have this issue? has anyone else seen this? it happens randomly a couple of times a day.
if anyone can point me to where i might be looking to fix this problem i would really appreciate.
thanks
chris
chrisr865
Re: PPPOE target
Tue Jun 07, 2022 7:45 am
hi all,
we now have 4 units doing this occasionally. have anyone come across this before?
where can i start looking for problems?
regards
chris
Users browsing this forum: Bing [Bot] and 80 guests
