gregoinc
Bonding Beginner
Wed May 18, 2022 9:17 am
New owner of Mikrotik CRS328-24P-4S+ units and I am attempting to configure port bonding. I read the documentation and attempted the commands below but it gave me an error?
[admin@NEWCORE] /interface bonding> add mode=802.3ad name=bond_15-16 slaves=ether15,ether16
failure: ether15 already in bridge
I am obviously missing something simple, so could a kind person help me get back on track.
Thanks, Mark
rextended
Re: Bonding Beginner  [SOLVED]
Wed May 18, 2022 10:31 am
Sometimes, reading the error line, it suggests the solution:
Now check inside
/interface bridge port print
if ether15 is present
Now check inside
/interface bonding print
if ether15 is present on another bonding
Zacharias
Wed May 18, 2022 11:00 am
The error message indicates you exactly what the problem is.
The port members of a bonding must not be slave interfaces of the Bridge itself. When you create the Bond interface, add that bond to the Bridge.
Also read here https://help.mikrotik.com/docs/display/ ... ng-Summary
gregoinc
Thu May 19, 2022 2:42 pm
Thank you rextended and Zacharias, I understand my question was probably frustrating. First time owner of Mikrotik, so I will get there eventually.
Here's the results...
[admin@NEWCORE] > /interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE        BRIDGE        HW  PVID PRIORITY  PATH-COST INTERNAL-PATH-COST    HORIZON
 0 I H ;;; defconf
       ether1        bridge        yes    1     0x80         10                 10       none
 1   H ;;; defconf
       ether2        bridge        yes    1     0x80         10                 10       none
 2 I H ;;; defconf
       ether3        bridge        yes    1     0x80         10                 10       none
 3 I H ;;; defconf
       ether4        bridge        yes    1     0x80         10                 10       none
 4 I H ;;; defconf
       ether5        bridge        yes    1     0x80         10                 10       none
 5 I H ;;; defconf
       ether6        bridge        yes    1     0x80         10                 10       none
 6 I H ;;; defconf
       ether7        bridge        yes    1     0x80         10                 10       none
 7   H ;;; defconf
       ether8        bridge        yes    1     0x80         10                 10       none
 8   H ;;; defconf
       ether9        bridge        yes    1     0x80         10                 10       none
 9   H ;;; defconf
       ether10        bridge        yes    1     0x80         10                 10       none
10 I H ;;; defconf
       ether11        bridge        yes    1     0x80         10                 10       none
11 I H ;;; defconf
       ether12        bridge        yes    1     0x80         10                 10       none
12 I H ;;; defconf
       ether13        bridge        yes    1     0x80         10                 10       none
13   H ;;; defconf
       ether14        bridge        yes    1     0x80         10                 10       none
14   H ;;; defconf
       ether15        bridge        yes    1     0x80         10                 10       none
15   H ;;; defconf
       ether16        bridge        yes    1     0x80         10                 10       none
16   H ;;; defconf
       ether17        bridge        yes    1     0x80         10                 10       none
17 I H ;;; defconf
       ether18        bridge        yes    1     0x80         10                 10       none
18   H ;;; defconf
       ether19        bridge        yes    1     0x80         10                 10       none
19 I H ;;; defconf
       ether20        bridge        yes    1     0x80         10                 10       none
20   H ;;; defconf
       ether21        bridge        yes    1     0x80         10                 10       none
21   H ;;; defconf
       ether22        bridge        yes    1     0x80         10                 10       none
22   H ;;; defconf
       ether23        bridge        yes    1     0x80         10                 10       none
23 I H ;;; defconf
       ether24        bridge        yes    1     0x80         10                 10       none
24 I H ;;; defconf
       sfp-sfpplus1        bridge        yes    1     0x80         10                 10       none
25   H ;;; defconf
       sfp-sfpplus2        bridge        yes    1     0x80         10                 10       none
26 I H ;;; defconf
       sfp-sfpplus3        bridge        yes    1     0x80         10                 10       none
27 I H ;;; defconf
       sfp-sfpplus4        bridge        yes    1     0x80         10                 10       none
[admin@NEWCORE] >
And this one...
[admin@NEWCORE] > /interface bonding print
This is the setup I am attempting to achieve.
Again, I appreciate the guidance.
Zacharias
Sat May 21, 2022 11:41 am
Remove ports ether1 and ether2 from the Bridge.
Then create the bonding interface with ports ether1 and ether2.
Finally, add the bonding interface to the Bridge.
As simple as that...
rextended
Sat May 21, 2022 6:54 pm
But the question is... That synology is capable to do bonding?
If a peripheral has multiple Ethernet ports, it doesn't necessarily mean they can be bonded together...
erlinden
Sat May 21, 2022 6:58 pm
I know for sure, got it working (though it is called link aggregation):
https://kb.synology.com/en-global/DSM/h ... ?version=6
rextended
Sat May 21, 2022 7:06 pm
Yes, but just from the pics, not all can know if that version is compatible or not to do bonding :roll:
holvoetn
Sat May 21, 2022 8:00 pm
Looks like DS416play or alike. If so, it can do bonding.
Most current devices are running DSM7 nowadays.
Zacharias
Sat May 21, 2022 9:21 pm
Exactly...
It supports 802.3ad...
Users browsing this forum: Amazon [Bot], fxcd, trmns and 54 guests
