jprietove
Trainer
Trainer
v7. OSPF adjacency problems when two neighbor has two different connections: one broadcast and one ptp
Wed May 18, 2022 12:40 pm
Hello, I've been testing OSPF in v7 and I think I've found a bug with adjacency establishment. I've configured the same scenario in GNS3 using x86 images of RouterOS with v.7.3beta40, v7.2.3 and v6.49.6. Results in v7 are not the expected. Results in v6 looks good.
The scenario is this:
And the configuration in v7:
# Configuration for R1 in v7
add name=loopback
/routing id
add id=10.255.255.1 name=id-ospf
/routing ospf instance
add disabled=no name=ospf-instance-1 router-id=id-ospf
/routing ospf area
add disabled=no instance=ospf-instance-1 name=backbone
add address=10.255.255.1 interface=loopback network=10.255.255.1
add address=192.168.1.1/24 interface=ether1 network=192.168.1.0
/routing ospf interface-template
add area=backbone disabled=no networks=192.168.1.0/24
/system identity
set name=R1
For R2:
# Configuration for R2 in v7
add name=loopback
/routing id
add id=10.255.255.2 name=id-ospf
/routing ospf area
add address=10.255.255.2 interface=loopback network=10.255.255.2
add address=10.0.0.1/30 interface=ether2 network=10.0.0.0
add address=192.168.1.2/24 interface=ether1 network=192.168.1.0
add area=backbone disabled=no networks=10.0.0.0/30 type=ptp
/system identity
set name=R2
For R3:
# Configuration for R3 in v7
add name=loopback
/routing id
/routing ospf area
add address=10.255.255.3 interface=loopback network=10.255.255.3
add address=192.168.1.3/24 interface=ether1 network=192.168.1.0
add address=10.0.0.2/30 interface=ether2 network=10.0.0.0
/system identity
set name=R3
In v7, routers are unable to get the adjacency. As an example, in v7.3beta40:
[admin@R2] > routing/ospf/neighbor/print
Flags: V - virtual; D - dynamic
 0  D instance=ospf-instance-1 area=backbone address=192.168.1.1 priority=128
      router-id=10.255.255.1 dr=192.168.1.2 bdr=192.168.1.2 state="TwoWay"
      state-changes=2 timeout=30s
 1  D instance=ospf-instance-1 area=backbone address=192.168.1.3 priority=128
      router-id=10.255.255.2 dr=192.168.1.2 bdr=192.168.1.2 state="ExStart"
      state-changes=3 timeout=34s
 2  D instance=ospf-instance-1 area=backbone address=10.0.0.2
      router-id=10.255.255.2 state="ExStart" state-changes=3 timeout=34s
[admin@R2] >
But equivalent config in RouterOS v6 works well:
# Config for R2 in v6. Similar config for R1 and R3
add name=loopback
set [ find default=yes ] router-id=10.255.255.2
add interface=ether2 network-type=point-to-point
/routing ospf network
add area=backbone network=192.168.1.0/24
add area=backbone network=10.0.0.0/30
/system identity
set name=R2
The adjacency can be established at OSPF Neighbors:
[admin@R2] > routing ospf neighbor print
 0 instance=default router-id=10.255.255.3 address=192.168.1.3 interface=ether1
   priority=1 dr-address=192.168.1.1 backup-dr-address=192.168.1.2
   state="Full" state-changes=4 ls-retransmits=0 ls-requests=0 db-summaries=0
   adjacency=15m50s
 1 instance=default router-id=10.255.255.3 address=10.0.0.2 interface=ether2
   priority=1 dr-address=0.0.0.0 backup-dr-address=0.0.0.0 state="Full"
   state-changes=5 ls-retransmits=0 ls-requests=0 db-summaries=0
   adjacency=16m3s
 2 instance=default router-id=10.255.255.1 address=192.168.1.1 interface=ether1
   state="Full" state-changes=5 ls-retransmits=0 ls-requests=0 db-summaries=0
   adjacency=16m10s
[admin@R2] >
I'm going to write to support but it would be nice if someone can test it or just check it is not my mistake.
jprietove
Trainer
Trainer
Re: v7. OSPF adjacency problems when two neighbor has two different connections: one broadcast and one ptp  [SOLVED]
Thu May 19, 2022 11:39 am
I finally found it was my mistake. R3 and R2 was assigned the same ID. When corrected, everything work as expected.
Users browsing this forum: mansuramir and 49 guests
