I was looking for ways to rename files on RouterOS.
Why? I like to modify my backup script, so that it only sends backup/export files if file size are change.
Testing for size is simple, so after backup is send, I will rename export to old_export file. Next run test size and if different send new export.
I did find a way to use FTP to rename the file, but problem with that is that you need a user with Full capability (write is not enough) and you need FTP services to run.
viewtopic.php?t=47511
Normis told in 2008! that he would look inn to move files (that would help):
viewtopic.php?p=117066#p117066
So not much has change in 14 years???
So this is a request to be able to move and rename files within scripts.
