gmoeller54
Mikrotik router board hex -- Poe switch -- MacBook pro 2015
Wed May 18, 2022 3:11 pm
Greetings
I'm so close to getting this figured out, I don't want to have to reset it again
What am I doing wrong?
If I had to boil it down, I believe I am now experiencing 2 issues.
1) shortly after choosing the default configuration, I can then go to my workstation which is behind a switch to start configuring. At that time, I am able to get to the router using 192.168.88.1. However, I am not able to access the internet after turning DHCP server on.
2) I decided to try a unique up in case there was something crashing into the default up vec it was assigned .88.1 also. So, I changed to .5.1 and now can't access at all
Using angry up, with a wide open range of 192.168.0.0 - 192.168.254.254 and waiting a long time, it doesnt find anything at all!?
I am not only wanting to reach the internet to get my work done, I am wanting to understand this better to one day have knowledge on the subject. Which is why I don't understand how after using such a basic and broad listener, it is not hearing anything.
Thank you for your time.
mcbrown90
Re: Mikrotik router board hex -- Poe switch -- MacBook pro 2015
Wed May 18, 2022 5:09 pm
You could try to use winbox, you can connect with mac address.
Winbox only runs on Windows, maybe you could install windows on a VM?
Larsa
Wed May 18, 2022 5:27 pm
It’s also possible to run WinBox on the Mac using Wine. Have a look at “How to install Winbox on macOS
Users browsing this forum: No registered users and 78 guests
