saburtwo
7.2.3 and IPv6 and SFP modules issues
Wed May 18, 2022 10:46 pm
Hi
I just upgraded my rb4011 to 7.2.3 and lost my IPv6 gateway :(
I looked into it and there was magically 2x default routes, both identical apart from was DAd+ and the other DAv+
Any ideas where the DAv+ has come from? It says v for vpn but that makes no sense
Now I have removed the default route with DAv+ from the routing table and my IPv6 works again. Weird.
Other issue I had was post upgrade the router would not boot with the SFP installed. And when it did boot with it removed as soon as i reinserted it it flashed and strobed the LEDs for all the interfaces and the SFP activity light and communication on any interface was lost to the router.
I let it boot and sit idle for a while then rebooted it again powered it off in the process and now SFP no longer stops all the traffic and works as expected.
Other than that the new Wire Guard VPN soo much less hassle than IPSec IKE etc very good
saburtwo
Re: 7.2.3 and IPv6 and SFP modules issues
Wed May 18, 2022 11:08 pm
Hi
It appears this additional default route reappears whenever my PPPoE connection is established leaving me with 2 default routes same distance but only difference being the 2nd one marked with v for vpn.. again I removed it and now my IPv6 traffic flows.
Znevna
Wed May 18, 2022 11:19 pm
Regarding IPv6, it's mentioned every few days on the forum
uncheck add default route from the DHCPv6 client
Two default routes are added even in RouterOS 6 if you checked add default route, but somehow only one was valid for some reason.
When having a PPPoE type WAN that is.
saburtwo
Thu May 19, 2022 1:29 pm
If i uncheck default route in dhcpv6 client then how will i get the default route from the isp?
Thank you
Znevna
Thu May 19, 2022 1:36 pm
Are you using PPPoE to connect to the ISP?
saburtwo
Thu May 19, 2022 2:10 pm
Hi
Yes that is correct
Thank you
Znevna
Thu May 19, 2022 2:16 pm
Ok, then please uncheck add default route from the DHCPv6 client
thank you
also read viewtopic.php?p=928436#p928436
and other mentions around the forum with pppoe dhcpv6 and default route (you can search, probably mentioned in the release topics more)
saburtwo
Thu May 19, 2022 2:23 pm
Ok
I disabled it and I have no default route so traffic now no longer flows
I don't understand why you keep shouting disable dhcpv6 default route. Once it is removed by disabling it obviously there is no route to any address outside the local range of the router.
Znevna
Thu May 19, 2022 2:29 pm
The PPPoE client sets the route (the one that you deleted manually). Reconnect your PPPoE client.
Here, I did some more searches for you:
viewtopic.php?p=916059#p916042
viewtopic.php?p=896048#p896048
saburtwo
Thu May 19, 2022 2:38 pm
Now it makes sense thank you
Its strange to me because in previous releases this has never been an issue, I had only 1 default route from the DHCPv6 client and never got a default route from the PPPoE client and certainly never had a route marked "v" for VPN
The only reason I set install default route in the first place under DHCPv6 was because the PPPoE client didn't give me a default route and I didnt want to create a static route
Thanks again
Users browsing this forum: bratislav, Google [Bot], herger, hnd, jaclaz, KpuCko, mtkvvv and 123 guests
