markfromv2v
Can't test WAN speed
Thu May 19, 2022 3:53 pm
Hi. I'm using two hAP ac routers and trying out CAPsMAN functionality.
When I'm connected to the router it does seem to put switch from one to another when I'm connected.
I also need to test speed and conectivity of this setup. And the problem is when I use two computers that are connected to this Wifi, (one is running a server and the other is running a test)
It always say that it wasn't able to make a connection and connect to the server.
What might be the problem for that?
holvoetn
Re: Can't test WAN speed
Fri May 20, 2022 7:59 am
In your capsman datapath config, have you allowed client communication ?
Edit: right term is client to client forwarding. Enable it.
While you are at it, considering using local forwarding. It will improve data speeds.
Users browsing this forum: complexxL9, Foxner, gerryho, GoogleOther [Bot], klambrev and 52 guests
