marcinkacper
Dual WAN, VLAN, IPSec IKEv2
Thu May 19, 2022 4:27 pm
I have problem with exchanging data by the VPN. I got the VPN login details from Octawave. There was a network address on the VPN side, however I don't know how to set up the Firewall.my actual setup:
IP Firewall NAT
 0    chain=srcnat action=accept src-address=10.150.10.0/24
      dst-address=192.168.100.0/24
 1    chain=srcnat action=masquerade src-address=192.168.100.0/23 log=no
      log-prefix="" ipsec-policy=out,none
 2    chain=srcnat action=masquerade src-address=192.168.200.0/24 log=no
      log-prefix=""
 3    chain=srcnat action=masquerade src-address=192.168.50.0/24 log=no
      log-prefix=""
 4    chain=srcnat action=masquerade src-address=192.168.40.0/24 log=no
      log-prefix=""
5    chain=srcnat action=masquerade out-interface=ether1 log=no log-prefix=""
6    chain=srcnat action=src-nat to-addresses=85.221.196.154
      src-address=10.150.10.0/24 out-interface=ether1 log=no log-prefix=""
IP Firewall
 0  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 1    chain=forward action=accept connection-state=established,related
      src-address=10.150.10.0/24 dst-address=192.168.100.0/24 log=no
      log-prefix="" ipsec-policy=in,ipsec
 2    chain=forward action=accept connection-state=established,related
      src-address=192.168.100.0/24 dst-address=10.150.10.0/24 log=no
      log-prefix="" ipsec-policy=out,ipsec
 3    chain=input action=accept protocol=udp src-address=176.119.63.106
      dst-port=4500 log=no log-prefix=""
 4 X  chain=input action=accept protocol=udp src-address=176.119.63.106
      dst-port=1701 log=no log-prefix=""
 5    chain=input action=accept protocol=udp src-address=176.119.63.106
      dst-port=500 log=no log-prefix=""
 6    chain=input action=accept protocol=ipsec-esp src-address=176.119.63.106
 7    ;;; defconf: accept out ipsec policy
      chain=forward action=accept ipsec-policy=out,ipsec
 8    ;;; defconf: accept in ipsec policy
      chain=forward action=accept ipsec-policy=in,ipsec
 9 X  ;;; FastTrack: established & related
      chain=forward action=fasttrack-connection
      connection-state=established,related log=no log-prefix=""
10    chain=forward action=fasttrack-connection
11 X  chain=forward action=accept connection-state=established,related log=no
      log-prefix=""
12    ;;; Accept Related or Established Connections
      chain=input action=accept connection-state=established,related log=no
      log-prefix=""
13    ;;; Accept New Connections
      chain=forward action=accept connection-state=new log=no log-prefix=""
14    ;;; Accept Related or Established Connections
      log-prefix=""
15    chain=input action=drop protocol=udp in-interface=ether1 dst-port=53 log=n>
      log-prefix=""
16    chain=input action=drop protocol=udp in-interface=ether2 dst-port=53 log=n>
      log-prefix=""
17    chain=input action=drop protocol=tcp in-interface=ether1 dst-port=53 log=n>
      log-prefix=""
18    chain=input action=drop protocol=tcp in-interface=ether2 dst-port=53 log=n>
      log-prefix=""
19    chain=forward action=drop in-interface=OFFICE out-interface=CCTV log=no
      log-prefix=""
20    chain=forward action=drop in-interface=CCTV out-interface=OFFICE log=no
      log-prefix=""
21    chain=forward action=drop in-interface=WIFI out-interface=CCTV log=no
      log-prefix=""
22    chain=forward action=drop in-interface=CCTV out-interface=WIFI log=no
      log-prefix=""
IP Address
 #   ADDRESS            NETWORK         INTERFACE
 0   192.168.100.1/23   192.168.100.0   OFFICE
 1   85.221.196.154/30  85.221.196.152  ether1
 2   192.168.200.1/24   192.168.200.0   WIFI
 3   192.168.50.1/24    192.168.50.0    CCTV
 4   192.168.40.1/24    192.168.40.0    MGMT
 5   192.168.88.2/24    192.168.88.0    ether2
 6 I 192.168.1.0/24     192.168.1.0     vlan1
IP IPSEC installed-sa
Flags: H - hw-aead, A - AH, E - ESP
 0  E spi=0x4F911F0 src-address=176.119.63.106 dst-address=85.221.196.154
      state=mature auth-algorithm=sha256 enc-algorithm=aes-cbc enc-key-size=256
      auth-key="xx"
      enc-key="xx"
      add-lifetime=19h12m20s/1d26s replay=128
 1  E spi=0xC348E7AF src-address=85.221.196.154 dst-address=176.119.63.106
      auth-key="xx"
      enc-key="xx"
policy print detail
Flags: T - template, B - backup,
X - disabled, D - dynamic, I - invalid, A - active, * - default
 0 T X* group=default src-address=176.119.63.106/32 dst-address=85.221.196.154/32
        protocol=all proposal=default template=yes
 1   A  peer=Octawave tunnel=yes src-address=192.168.100.0/24 src-port=any
        dst-address=10.150.10.0/24 dst-port=any protocol=all action=encrypt
        level=require ipsec-protocols=esp sa-src-address=85.221.196.154
        sa-dst-address=176.119.63.106 proposal=Oktawave ph2-count=1
anyone can repair my cofiguration?
Users browsing this forum: Bing [Bot], BradK, yonutm and 68 guests
