pehac
Basic Wifi setup
Thu May 19, 2022 8:23 pm
Hi everyone
new to Mikrotik world and struggling to set up wifi with internet. I'm using Cap AC as router with following setting:
Poe in = cable internet + power
Poe out = connected to laptop just for the sake of testing
Router setting: home AP Dual (followed all basic setting), config file below
Problem:
1) I'm able to connect my laptop to wifi but no internet is availabe (if I connect thru cable its ok)
2) I'm not able to connect my phone to wifi with error message "couldnt get IP address"
config:
# may/19/2022 19:01:28 by RouterOS 6.48.4
# software id = C8EJ-R4T2
# model = RouterBOARD cAP Gi-5acD2nD
# serial number = 9AA90960D379
add admin-mac=B8:69:F4:51:46:4D auto-mac=no comment=defconf name=bridgeLocal
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country="czech republic" \
disabled=no frequency=auto mode=ap-bridge ssid=Becky&Magal_2G \
wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac country="czech republic" \
disabled=no frequency=auto mode=ap-bridge ssid=Becky&Magal_5G \
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \
mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=\
*************** wpa2-pre-shared-key=***************
/ip hotspot profile
add name=dhcp ranges=192.168.88.3-192.168.88.254
add address-pool=dhcp disabled=no interface=bridgeLocal name=dhcp1
add bridge=bridgeLocal comment=defconf disabled=yes interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
add interface=ether1 list=WAN
add interface=bridgeLocal list=LAN
/interface wireless cap
set bridge=bridgeLocal discovery-interfaces=bridgeLocal interfaces=\
wlan1,wlan2
add address=192.168.88.1/24 interface=bridgeLocal network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=bridgeLocal
add disabled=no interface=ether1
add address=192.168.88.0/24 gateway=192.168.88.1 netmask=24
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Prague
Any help would be appreciated
pehac
anav
Re: Basic Wifi setup
Fri May 20, 2022 5:53 pm
(1) If this is a public facing Router, then you need better firewall rules......... (aka you get at public IP address).
{Input Chain}
add action=accept chain=input in-interface-list=LAN
add action=drop chain=input comment="drop all else"
{forward chain}
add action=accept chain=forward comment="allow internet traffic" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="allow port forwarding" connection-nat-state=dstnat
add action=drop chain=forward
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface-list=WAN
(2) Remove bridge from /IP DHCP CLIENT! It has nothing to do with your ISP, as you correctly note in your interface list members!
/ip dhcp-client
(3) To get things working, you are almost there delete this line............. not required!!!
wlan1,wlan2
and MODIFY THIS LINE /interface bridge port..................
add bridge=bridgeLocal interface=wlan1
add bridge=bridgeLocal interface=wlan2
add bridge=bridgeLocal interface=ether2
Finally food for thought, I prefer if possible to config or at least have the possiblity to config the capac from ether2 What I Call OFF BRIDGE.
This assumes the capac is accessible (low ceiling, side of wall) where you can hookup an ethernet cable to your laptop and ether2, OR if you had forethought when installing the capac to run an ethernet cable from ether2 to an accessible location......to do the same hookup.
viewtopic.php?t=181718
Users browsing this forum: Bing [Bot], complexxL9, StokkiesA, tdw and 58 guests
