autominus
Hex S or hAP ac3
Thu May 19, 2022 9:41 pm
I plan to purchase a new router. I'm still trying to decide between RB760iGS (Hex S) and RBD53iG-5HacD2HnD (hAP ac3).
I want do to some layer 3/4 filtering and VPN connections to other routers over the internet. I have two ISP - one via ethernet connection and two via usb modem LTE.
Additionally, I'm planning to use a VXLAN configuration.
May anyone of you know which device has the better performance?
Thank you in advance!
anav
Re: Hex S or hAP ac3
Thu May 19, 2022 9:51 pm
Current and future throughput of Primary ISP connection (leaning towards hapac3 due to newer build and better capacity).
The hapac2 is better bang for the buck then the hex at the same price point and has USB Modem capability 4G/LTE for cellular, the hapac3 usb is for storage only as they have a hapac3 lte model that adds cellular functionality as well.
autominus
Thu May 19, 2022 10:40 pm
Does the hAP ac2 has better switching chips, processor bus etc. ?
I mean the model RBD52G-5HACD2HND-TC.
anav
Fri May 20, 2022 5:08 am
YOu can look that up yourself.........
https://mikrotik.com/products/group/wir ... and-office
kevinds
Long time Member
Long time Member
Mon May 23, 2022 10:14 pm
The hAP ac x models that I've use seem to run hot.. Hotter than I was comfortable with for long-term use anyways..
https://mikrotik.com/product/hex_s#fndtn-testresults
https://mikrotik.com/product/hap_ac3#fndtn-testresults
Users browsing this forum: mhenriques, pav5, xrlls and 126 guests
