siwatsirichai
Wireguard Site-to-Site can't connect from bridge
Fri May 20, 2022 8:59 am
The situation is that I have a Site-to-Site Wireguard VPN between pfSense and hap ac3
I can ping the device at home if I set "interface=homevpnclient" but when I use "interface=bridge", it timed out
[admin@MikroTik] /tool> ping 192.168.0.134 interface=bridge
  SEQ HOST                                     SIZE TTL TIME       STATUS
    0 192.168.0.134                                                timeout
    1 192.168.0.134                                                timeout
    2 192.168.0.134                                                timeout
    3 10.100.2.1                                 84  64 127ms188us host unreac...
    4 192.168.0.134                                                timeout
    sent=5 received=0 packet-loss=100%
[admin@MikroTik] /tool> ping 192.168.0.134 interface=homevpnclient
    0 192.168.0.134                              56  63 161ms362us
    1 192.168.0.134                              56  63 286ms419us
    sent=2 received=2 packet-loss=0% min-rtt=161ms362us avg-rtt=223ms890us
   max-rtt=286ms419us
Home Network: 192.168.0.0/16
Mikrotik Network: 10.100.2.0/24
Configuration:
# may/20/2022 12:57:00 by RouterOS 7.2.3
# software id = Q9US-L2X7
# model = RBD53iG-5HacD2HnD
# serial number = F34E0F51C32B
add admin-mac=DC:2C:6E:13:64:D8 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=MikroTik-1364DC wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
    ap-bridge ssid=MikroTik-1364DD wireless-protocol=802.11
/interface wireguard
add listen-port=13231 mtu=1420 name=homevpnclient
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=10.100.2.100-10.100.2.200
add address-pool=default-dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
/interface wireguard peers
add allowed-address=192.168.0.0/16,10.15.210.1/32,::/0 endpoint-address=\
    siwatsystem.com endpoint-port=51820 interface=homevpnclient \
    persistent-keepalive=10s public-key=\
add address=10.100.2.1/24 interface=bridge network=10.100.2.0
add address=10.15.210.3/24 interface=homevpnclient network=10.15.210.0
/ip dhcp-client
add address=10.100.2.0/24 comment=defconf dns-server=10.100.2.1 gateway=\
    10.100.2.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=forward dst-address=192.168.0.0/16 src-address=\
    10.100.2.0/24
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
add check-gateway=ping disabled=no distance=1 dst-address=192.168.0.0/16 \
    gateway=10.15.210.1 pref-src=0.0.0.0 routing-table=main scope=30 \
    suppress-hw-offload=no target-scope=10
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    "defconf: drop everything else not coming from LAN" in-interface-list=!LAN
    invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
    src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
    dst-address-list=bad_ipv6
    icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
    protocol=udp
    ipsec-ah
    ipsec-esp
/system clock
set time-zone-name=Asia/Bangkok
/tool mac-server
/tool mac-server mac-winbox
siwatsirichai
Re: Wireguard Site-to-Site can't connect from bridge
Fri May 20, 2022 11:07 am
I tried to ping the address from a LAN computer, it got through
now, the problem is that I can't access access a HTTP server in the home network, with I curl in the client computer, it timed out
but when I use fetch in mikrotik, it works fine.
SSH to the home server does work, however.
anav
Fri May 20, 2022 6:25 pm
There are not that many things to check.
1. wireguard settings, usually an issue with allowed IPs.
2. firewall rules, which allow wg traffic to enter the tunnel outbound, OR which allow external users incoming out of the wireguard tunnel to the local LAN, or to the router for config, or to the internet (localWAN).
3. IP routes, to direct traffic to the tunnel (outbound traffic or return traffic for external users).
viewtopic.php?p=906311
Users browsing this forum: No registered users and 110 guests
