jamshidm66
Default Route with addressList
Fri May 20, 2022 9:28 am
hi all
i have an addressList contains some name based addresses for example:upgradeDest , this addresses can be reached only by pppoe internet
also i have an pppoe intranet which is default gateway on the router
now i have to forward that address list destination through internet
so how can i define this route based on below screen shot attached in route table of mikrotik ?
thanks in advance
rextended
Re: Default Route with addressList
Fri May 20, 2022 10:32 am
The "right" way is using firewall mangle to mark routing when the dst-source is inside the address list.
Search on the forum, is full of examples.
Larsa
Fri May 20, 2022 11:55 am
Hi @jamshidm66, here is one example how to solve it: "Routing an address-list"
Users browsing this forum: No registered users and 26 guests
