sander123
BGP local pref not working?
Fri May 20, 2022 11:15 am
Maybe i have something wrong, but why are both routes active while the first one has a local pref of 120 and the second of 100
I get more routes from other BGP peers for this subnet but they are not active as correct.
Running ROS 7.1.5
Ab + afi=ip4 contribution=active dst-address=185.xxx.xx.0/22 routing-table=main gateway=185.1.xxx.xxx
immediate-gw=185.1.xxx.xxx%Speed-IX-vlan1001 distance=20 scope=40 target-scope=10
belongs-to="BGP IP routes from 185.1.xxx.xxx"
bgp.peer-cache-id=*B00001A .as-path="420xx,573xx" .local-pref=120 .atomic-aggregate=yes .origin=igp
debug.fwp-ptr=0x202C912
Ab + afi=ip4 contribution=active dst-address=185.xxx.xx.0/22 routing-table=main gateway=178.xxx.xx.xx
immediate-gw=178.xxx.xx.xx%vlan50-Uplink distance=20 scope=40 target-scope=10
belongs-to="BGP IP routes from 178.xxx.xx.xx"
bgp.peer-cache-id=*B000002 .as-path="420xx,573xx" .local-pref=100 .atomic-aggregate=yes .origin=igp
debug.fwp-ptr=0x202C2C60
sander123
Re: BGP local pref not working?
Fri May 20, 2022 11:56 am
I see it is using ECMP, but why dus it ignore the local-pref difference?
Is there another (better) option to prio specific paths through routing filters?
update:
Also it uses ECMP for some subnets while the AS path is longer, so way isn't it routing through the shortest path?
sander123
Re: BGP local pref not working?  [SOLVED]
Mon May 23, 2022 11:57 pm
Found the problem.
I had exported/imported BGP templates from another router and forgot to change the local router-id
After changing al is working like expected.
Users browsing this forum: loloski and 34 guests
