anassar26
Please help.. to solve invalid value " an integer required " error
Fri May 20, 2022 3:52 pm
Please help when applying the following script it gives an error “invalid value for limit-bytes-total, an integer required” and I can’t find the problem or fix it
Script :
:foreach i in=[/ip hotspot user find ] do={
:local email [/ip hotspot user get value-name=email $i ]
:local downquotamb [:tonum [:pick $email 0 3]]
:local downquota ($downquotamb * 1000)
:put $downquota
/ip h us set $i  limit-bytes-total=$downquota
rextended
Re: Please help.. to solve invalid value " an integer required " error
Fri May 20, 2022 3:54 pm
what is this?
$downquota print
But the point is: what is get from email is correct?
All user have correctly set the email?
anassar26
Fri May 20, 2022 3:59 pm
what is this?
$downquota print
Sorry, miss typing it has been modified
anassar26
Fri May 20, 2022 4:07 pm
Thank you .. but give the same result "invalid value for limit-bytes-total, an integer required"
email format "100GB@30.512M"
rextended
Fri May 20, 2022 4:14 pm
Some users have invalid email... or real email?
anassar26
Fri May 20, 2022 4:18 pm
Amazing.. the script is working fine. Thank you very much
rextended
Fri May 20, 2022 4:20 pm
If user have for example "50GB@30.512M" instead of 100G picking first 3 char result on not valid number "50G"
And assign kilobit, but must correctly add at the end "M" for Megabit
anassar26
Fri May 20, 2022 4:30 pm
It is possible to modify the script to get the following values ​​for each user
Suppose we need to get the following values
100G....100 gaigbytes
30D.... 30 dayes
512M... profile 512M
from email structure " 100G@30D.512M "
rextended
Fri May 20, 2022 4:33 pm
You check this?
rextended
Re: Please help.. to solve invalid value " an integer required " error  [SOLVED]
Fri May 20, 2022 4:34 pm
The schema is everytime:
<GIGA>G@<DAYS>.<PROFILE NAME> ???
/ip hotspot user
:foreach user in=[find where !default and !dynamic] do={
    :local email      [get $user email]
    :local totalquota ([:tonum [:pick $email 0 [:find $email "G"] ] ] * 1000)
    :local days       [:pick $email ([:find $email "@"] + 1) [:find $email "."] ]
    :local profile    [:pick $email ([:find $email "."] + 1) [:len $email] ]
    :if ([:typeof $totalquota] = "num") do={set $user limit-bytes-total=($totalquota."M")}
    :put "$[get $user name] limit-bytes-total=$($totalquota."M") days=$days profile=$profile"
Avoid "G", "@" and "." on profile name...
anassar26
Fri May 20, 2022 4:39 pm
Thank you very much for your kindness
rextended
Fri May 20, 2022 4:40 pm
No problem, thanks to you.
rextended
Fri May 20, 2022 4:46 pm
I notice now: limit-bytes-total limits the sum of up + down, not only download.
Is wanted? I ask because the variable on your script is called "downquota"
and set limit-bytes-total, not limit-bytes-out
anassar26
Fri May 20, 2022 7:05 pm
I need to modify the last script in the form below to make it work correctly. I added some additions to meet my requirements, but I encountered some difficulties when trying the script, such as it cannot be changed.”uptime “ I also want to change my script variable to download limit
Thank you very much for your interest
I appreciate your efforts
Users browsing this forum: Google [Bot] and 26 guests
