hci
Long time Member
Long time Member
System Scheduler and Scripts
Fri May 20, 2022 5:02 pm
I have a system scheduler with multiple lines like this running hourly or so:
/tool fetch url="https://some_ipv6_only_url_tec_dot_com.co" keep-result=no
/tool fetch url="https://some_other_url_tec_dot_com.co" keep-result=no
/tool fetch url="https://some_another_tec_dot_com.co" keep-result=no
There for updating dynamic DNS etc. but it seems as though if it fails to get the first URL say IPv6 is down at moment the other lines on down do not run. Does that make sense? Is there way to make sure all the lines in the scheduler script run even if there is an error on first line? Its not really a code error it just could not retrieve URL.
rextended
Re: System Scheduler and Scripts  [SOLVED]
Fri May 20, 2022 5:20 pm
:exec "/tool fetch url=\"https://some_ipv6_only_url_tec_dot_com.co\" keep-result=no"
:exec "/tool fetch url=\"https://some_other_url_tec_dot_com.co\" keep-result=no"
:exec "/tool fetch url=\"https://some_another_tec_dot_com.co\" keep-result=no"
hci
Long time Member
Long time Member
Fri May 20, 2022 5:35 pm
That fixed it. Thanks.
Users browsing this forum: No registered users and 44 guests
