Leonardorortizm
Router is Killing all peers Ospf
Fri May 20, 2022 5:07 pm
Hi, i have a CCR1072-1G-8S+ running BGP and Ospf as internal, the router drop down all Ospf peers at the same time, this has happened to someone else?
The interface is not disconecting and not lose L2 comunication when occurs....
may/19 19:52:26 route,ospf,info OSPFv2 neighbor 10.11.0.80: state change from Full to Down
may/19 19:52:26 route,ospf,info OSPFv2 neighbor 10.11.0.113: state change from Full to Down
may/19 19:52:26 route,ospf,info OSPFv2 neighbor 10.11.0.116: state change from Full to Down
may/19 19:52:34 route,ospf,info OSPFv2 neighbor 10.11.0.110: state change from Full to Down
may/19 19:52:36 route,ospf,info Ignoring Link State Acknowledgment packet: wrong peer state
may/19 19:52:36 route,ospf,info state=Attempt
may/19 19:52:36 route,ospf,info state=ExStart
may/19 19:52:37 route,ospf,info Ignoring Link State Acknowledgment packet: wrong peer state
may/19 19:52:37 route,ospf,info state=ExStart
may/19 19:52:43 route,ospf,info Ignoring Link State Acknowledgment packet: wrong peer state
may/19 19:52:43 route,ospf,info state=Attempt
may/19 19:56:11 route,ospf,info OSPFv2 neighbor 10.11.0.117: state change from Full to Down
may/19 19:59:51 route,ospf,info OSPFv2 neighbor 10.11.0.110: state change from Full to Down
may/19 20:00:05 route,ospf,info OSPFv2 neighbor 10.11.0.80: state change from Full to Down
may/19 20:00:05 route,ospf,info OSPFv2 neighbor 10.11.0.70: state change from Full to Down
may/19 20:00:05 route,ospf,info Ignoring Link State Acknowledgment packet: wrong peer state
may/19 20:00:05 route,ospf,info state=Down
may/19 20:00:12 route,ospf,info Ignoring Link State Acknowledgment packet: wrong peer state
may/19 20:00:12 route,ospf,info state=Attempt
may/19 20:00:12 route,ospf,info state=Down
may/19 20:02:10 route,ospf,info OSPFv2 neighbor 10.11.0.117: state change from Full to Down
may/19 20:02:20 route,ospf,info OSPFv2 neighbor 10.11.0.70: state change from Full to Down
may/19 20:04:14 route,ospf,info OSPFv2 neighbor 10.11.0.80: state change from Full to Down
may/19 20:04:28 route,ospf,info OSPFv2 neighbor 10.11.0.113: state change from Full to Down
may/19 20:04:28 route,ospf,info OSPFv2 neighbor 10.11.0.110: state change from Full to Down
UplinkLLC
Re: Router is Killing all peers Ospf
Sat May 21, 2022 3:28 am
Hello Leonardorortizm,
What version of RouterOS are you using on the CCR1072-1G-8S+ ?
Leonardorortizm
Sat May 21, 2022 4:03 pm
Hi, im using v6.49.5 RouterOs
nichky
Sun May 22, 2022 11:16 am
how your NAT looks like?
Leonardorortizm
Mon May 23, 2022 3:23 pm
Hi mate , thanks for write, i have solve it.
The problem was CPU usage over 75%. I was thinking that for an router too big as CCR1072 75% was'nt much.-
Leonardorortizm
Sat Jun 04, 2022 10:40 pm
Hi, the problem has occurred again with cpu usage in 33%, i don't now what i can do for solve it!.
Jun/04/2022 13:25:45 route,ospf,info OSPFv2 neighbor 10.11.0.70: state change from Full to Down
Jun/04/2022 13:25:45 route,ospf,info OSPFv2 neighbor 10.11.0.77: state change from Full to Down
Jun/04/2022 13:25:45 route,ospf,info OSPFv2 neighbor 10.11.0.84: state change from Full to Down
Jun/04/2022 13:25:45 route,ospf,info OSPFv2 neighbor 10.11.0.116: state change from Full to Down
Jun/04/2022 13:25:45 route,ospf,info OSPFv2 neighbor 10.11.0.113: state change from Full to Down
Jun/04/2022 13:25:45 route,ospf,info OSPFv2 neighbor 10.11.0.110: state change from Full to Down
Jun/04/2022 13:25:45 route,ospf,info OSPFv2 neighbor 10.11.0.80: state change from Full to Down
Jun/04/2022 13:25:45 route,ospf,info OSPFv2 neighbor 10.11.0.117: state change from Full to Down
Jun/04/2022 13:25:45 route,bgp,error HoldTimer expired
Jun/04/2022 13:25:45 route,bgp,error RemoteAddress=179.1.77.57
Jun/04/2022 13:25:45 route,bgp,error Unexpected UPDATE message
Jun/04/2022 13:25:45 route,ospf,info Ignoring Link State Acknowledgment packet: wrong peer state
Jun/04/2022 13:25:45 route,ospf,info state=Attempt
Jun/04/2022 13:25:46 route,ospf,info Ignoring Link State Acknowledgment packet: wrong peer state
Jun/04/2022 13:25:46 route,ospf,info state=ExStart
Jun/04/2022 13:25:46 route,ospf,info state=Attempt
I have other two CCR1072 with the same configuration without problems
This is my NAT
9 ;;; NAT
chain=srcnat action=same to-addresses=(BGP Public range) same-not-by-dst=yes
protocol=!ospf src-address-list=Zarzal dst-address-list=!LAN log=no log-prefix=""
10 ;;; NAT
chain=srcnat action=same to-addresses=(other BGP Public range) same-not-by-dst=yes
protocol=!ospf src-address-list=ITX-RUTA-CRUZ dst-address-list=!LAN log=no log-prefix=""
nichky
Mon Jun 06, 2022 7:47 am
let see what the log saying:
/system logging action
add name=ospf target=memory
/system logging
add action=ospf topics=ospf
Leonardorortizm
Mon Jun 06, 2022 4:54 pm
nichky
Tue Jun 07, 2022 5:45 am
ospf doing what supposed to be doing
Things to check:
Duplicated router ids
Areas and types
Network Type
you mentioned above that you are experiencing high CPU, is that because of ospf? how about if u disable it.
can we get export file?
have u checked maybe / tool profile
UplinkLLC
Tue Jun 07, 2022 7:40 am
Not sure if this is your issue, but see this thread: viewtopic.php?t=116968
Leonardorortizm
Tue Jun 07, 2022 4:40 pm
@nichky
thanks, i will be reviewing your suggestions.
About cpu usage was solved reducing the amount of traffic that was being sent by mangle routing mark (3GB).
When the cpu usage was high /tool profile shows: routing and firewall are the most that consuming cpu.
Ok i understand that i can have a problem with Ospf, but this not explain why the router is killing BGP too.
Leonardorortizm
Thu Jun 09, 2022 3:28 pm
@UplinkLLC
It has not worked for me.
nichky
Fri Jun 10, 2022 2:17 am
once u get high CPU
check / tool profile and show us here
Leonardorortizm
Fri Jun 10, 2022 5:34 pm
The cpu was not high anymore
this is when router is down
AME CPU USAGE
flash 0%
firewall 0.9%
networking 0.7%
winbox 0.1%
logging 0.2%
management 0.3%
encrypting 0%
routing 1.2%
profiling 0.7%
queuing 0.1%
l7-matcher 0%
unclassified 1.1%
total 5.3%
console 0%
flash 0%
firewall 0.8%
networking 0.7%
winbox 0%
logging 0%
management 0.2%
encrypting 0%
routing 1.3%
profiling 0.1%
queuing 0.1%
l7-matcher 0%
unclassified 0.1%
total 3.3%
snmp 0%
console 0%
flash 0%
firewall 0.9%
networking 0.8%
winbox 0.2%
logging 0.3%
management 0.7%
encrypting 0%
routing 1.3%
profiling 0.2%
queuing 0.2%
l7-matcher 0%
unclassified 0.2%
total 4.8%
Leonardorortizm
Wed Jun 15, 2022 8:57 pm
Same problem unsolved here
viewtopic.php?t=122671
Leonardorortizm
Re: Router is Killing all peers Ospf  [SOLVED]
Tue Jun 21, 2022 3:18 pm
I has solved the issue, the problem was that the router has receiving an high amount of updates by BGP protocol (about 2 Millions) , the router can't manage this and them kill the BGP process, BGP and OSPF runs under the same process, for this reason all is down when occurs.
the solve was to talk with internet provider and request that only sends to me the default gateway.
I'm not convenced that Mikrotik 1072 could manage Full Routing BGP. Support has said that update to RouterOs V7 could solve the initial issue.
UplinkLLC
Wed Jun 22, 2022 7:00 pm
Mark the problem as solved please.
Thank you,
Users browsing this forum: No registered users and 28 guests
