pospanko
Putting router to sleep for a some time...
Thu Sep 20, 2007 7:50 am
I'm searching for a script that could put MT into sleep, or just put all interfaces off. This is important because occasionlly, on stormy weather, my wireless cards die...
Is there a way to succesfully do this?
pedja
Long time Member
Long time Member
Re: Putting router to sleep for a some time...
Thu Sep 20, 2007 6:45 pm
Just disabling interface won't help. Detaching antenna cable from interfaces may help.
pospanko
Fri Sep 21, 2007 12:32 am
Yes, I was afraid of that answer because that isnt't solution for me. Access points are too far from me to do something like that. So, I only can prey that my cards won't go to junk jard...
undrtkr
Mon Sep 24, 2007 8:51 pm
your cards die just because the storm, or by electrical discharges?
i've never seen cards dying only because a heavy storm
if the problem is electrical discharges, you can put some protection near your antennas
hpe this helps you
unlimitedme
Tue Sep 25, 2007 10:47 am
IMHO,
it is better if you use some power surge protector, rather than make it "sleep".
