redking
Problem with Ubiquiti cloud controller when APs are behind a Mikrotik
Sat May 21, 2022 5:16 pm
Hi and sorry for bad english,
I usually setup and check status of ubiquiti APs with cloud controller (changing inform path with "set-inform http://MYDDNS:8080/inform" command) and they work perfectly from all over the world.
The problem is when they are behind a mikrotik router with an hotspot configured, in this case in my ubiqui controller all tha APs are OFFLINE.
I've try to binding (bypassed) the MACs of APs and to add MYDDNS to the walled garden but no way!!!
Is there a way to solve this problem?
thanks
regards
RK
erlinden
Re: Problem with Ubiquiti cloud controller when APs are behind a Mikrotik
Sat May 21, 2022 6:13 pm
Think you need both port forward and hairpin nat.
tdw
Sat May 21, 2022 6:25 pm
For outbound UniFi APs -> controller connections you only need to add hotspot IP bindings, MAC and IP addresses.
redking
Sat May 21, 2022 6:26 pm
thanks for answer but how to do that excactly?
tdw
Sat May 21, 2022 7:10 pm
We have always used
/ip hotspot ip-binding
add mac-address=XX:XX:XX:XX:XX:XX address=NNN.NNN.NNN.NNN to-address=NNN.NNN.NNN.NNN type=bypassed
with the device address either set statically or getting it from a static DHCP lease. Never tried it without the addresses, the wiki isn't clear what would happen in that case.
redking
Sat May 21, 2022 7:28 pm
this is mac of AP?
and this the fixed IP of AP?
and this the destination? in thi case it's not an IP but a DDNS like xxxxxxx.synology.me
i'll try and i'll let you know
thanks
tdw
Sat May 21, 2022 7:56 pm
Yes, AP MAC address.
Both IP addresses are the same fixed IP of the AP. The to-address is part of the internal hotspot translation system, it has nothing to do with the destination of traffic from the AP.
redking
Sat May 21, 2022 7:58 pm
We have always used
does'nt work : (
tdw
Sat May 21, 2022 8:08 pm
Works on our hotspots. Can the AP resolve the inform URL address, the AP DNS server address would typically be set to the same as the gateway address, and does the Mikrotik apply srcnat to the outbound WAN traffic?
redking
Sat May 21, 2022 8:40 pm
It's really strange becouse if I login in ssh to the AP from the mikrotik internal terminal and try to ping my inform address it's resolved without problem
tdw
Sat May 21, 2022 9:04 pm
That suggests it is something else if pings are successfully bypassing the hotspot, maybe additional firewall rules. You can use the packet sniffer, filter on the IP address of the AP.
redking
Sun May 22, 2022 10:22 am
I disbaled all firewall rule but same problem
erlinden
Sun May 22, 2022 6:09 pm
What is the Unifi controller hosting (Cloud key or Local server)?
Is the MYDDNS name resolved to your public IP address?
If both true, please check my previous response.
redking
Mon May 23, 2022 3:50 pm
there's no controller, I modified the informer of ubiquiti via ssh (and outside of mikrotik it works perfectly!!)
How I told if I ping from ubiquiti (via ssh) mi informer ddns address I can resolve it without problem.
tried also Hairpin and port forwording, No Way!
Users browsing this forum: No registered users and 55 guests
