Hello All,
I am new to MikroTik Routers and RouterOS but I am looking for a configurable solution to manage WAN access on the DHCP server. I have configured a firewall rule to reject outputs from the local LAN by creating an IP group 10.1.10.60-10.1.10.254 I then set my DHCP server range to 10.1.10.60-10.1.10.254 this way anything that is on the DHCP server doesn't have access to the internet.
I then assign static IP addresses to the devices that I want to have internet inbetween the range of 10.1.10.2-10.1.10.59.
The issue that I am having is that anything with a static IP address doesn't seem to be able to talk to WAN or the router. I have done nothing to the router except these changes from the basic setup.
Ultimately I am want to limit WAN access to specific IP addresses that I can assign. Everything else on DHCP should have LAN access but no Wan access. If there is a better way to do this I am all ears or any help setting up this configuration would be very helpful.
Thank for the your time.
