alfred998
Large share transfers (>100MB) drop over wifi with CAPsMAN
Sun May 22, 2022 7:11 pm
I have been getting back to this problem for months, but can't seem to solve it.
There are two cAP ac managed by CAPsMAN on hEX and a simple Share on CentOS. There are no problems whatsoever between wired PC-s and the Share, while laptops on wireless can't transfer files (download or upload) over 100MB.
The transfer starts normally then drops to 0kbps and I get a 0x8007003b error :
Error 0x8007003B seems related to unstable connections or misconfiguration.
The caps serve both 2.4 and 5GHz under the same SSID and there is a second SSID for guests.
hEX :
# may/07/2022 13:05:45 by RouterOS 6.48.6
# software id = xxxx-xxxx
# model = RB750Gr3
# serial number = xxxxxxxxxxxx
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz extension-channel=disabled \
    frequency=2462 name=2ghz
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=eeCe name=\
    5ghz
add name=gst-brg
add arp=proxy-arp igmp-snooping=yes name=lim-brg
add arp=proxy-arp igmp-snooping=yes name=loc-brg priority=0x1000
add name=pub-brg
add name=wif-brg
set [ find default-name=ether3 ] loop-protect=on rx-flow-control=on \
    tx-flow-control=on
/caps-man datapath
add bridge=wif-brg name=office
add bridge=gst-brg name=guest
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm \
    name=office
    name=guest
/caps-man configuration
add channel=2ghz country=greece datapath=office distance=indoors \
    installation=indoor name=ofc2 security=office ssid=Office
add channel=5ghz country=greece datapath=office distance=indoors \
    installation=indoor name=ofc5 security=office ssid=Office
add channel=2ghz country=greece datapath=guest distance=indoors installation=\
    indoor name=gst2 security=guest ssid=Guests
add channel=5ghz country=greece datapath=guest distance=indoors installation=\
    indoor name=gst5 security=guest ssid=Guests
add name=WAN
add name=LAN
add name=LIM
add name=guest-pool ranges=10.10.10.150-10.10.10.250
add name=main-pool ranges=192.168.1.210-192.168.1.240
add name=l2tp-pool ranges=192.168.1.25-192.168.1.45
add name=wifi-pool ranges=11.11.11.30-11.11.11.130
add address-pool=main-pool disabled=no interface=loc-brg lease-time=3h name=\
    main-dhcp
add address-pool=guest-pool disabled=no interface=gst-brg lease-time=1h name=\
    guest-dhcp
add address-pool=wifi-pool disabled=no interface=wif-brg lease-time=3h name=\
    wifi-dhcp
/ppp profile
add bridge=loc-brg dns-server=8.8.8.8 interface-list=LAN local-address=\
    192.168.1.1 name=l2tp-loc remote-address=l2tp-pool use-encryption=\
    required
add bridge=lim-brg dns-server=8.8.8.8 interface-list=LIM local-address=\
    192.168.1.1 name=l2tp-lim remote-address=l2tp-pool use-encryption=yes
/queue simple
add disabled=yes max-limit=4M/4M name="WiFi Guest" target=gst-brg
add disabled=yes dst=pub-brg max-limit=30M/125M name=test-queue queue=\
    default/default target=192.168.1.144/29
add disabled=yes dst=pub-brg max-limit=40M/50M name=1test queue=\
    default/default target=loc-brg
/snmp community
add addresses=192.168.1.2/32 authentication-protocol=SHA1 \
    encryption-protocol=AES name=snmp3 security=private write-access=yes
add addresses=192.168.1.2/32 name=snmp2
/system logging action
add disk-file-count=1 disk-file-name=disk1/log/vpn disk-lines-per-file=10000 \
    name=vpn target=disk
add disk-file-count=1 disk-file-name=disk1/log/login name=login target=disk
add disk-file-count=1 disk-file-name=disk1/log/caps name=caps target=disk
add disk-file-count=1 disk-file-name=disk1/log/error disk-lines-per-file=2000 \
    name=error target=disk
add disk-file-name=disk1/log/fw disk-lines-per-file=10000 name=firewall \
    target=disk
/user group
set read policy="local,telnet,ssh,reboot,read,test,winbox,password,sniff,sensi\
    tive,api,romon,dude,tikapp,!ftp,!write,!policy,!web"
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
add name=user policy="telnet,reboot,read,test,winbox,!local,!ssh,!ftp,!write,!\
    policy,!password,!web,!sniff,!sensitive,!api,!romon,!dude,!tikapp"
add name=dude policy="read,winbox,dude,!local,!telnet,!ssh,!ftp,!reboot,!write\
    ,!policy,!test,!password,!web,!sniff,!sensitive,!api,!romon,!tikapp"
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes \
    require-peer-certificate=yes upgrade-policy=suggest-same-version
/caps-man manager interface
add interface=loc-brg
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=\
    ofc5 name-format=identity slave-configurations=gst5
add action=create-dynamic-enabled hw-supported-modes=g master-configuration=\
    ofc2 name-format=identity slave-configurations=gst2
add bridge=loc-brg interface=ether3
add bridge=loc-brg interface=ether4
add bridge=loc-brg interface=ether5
add bridge=pub-brg interface=ether2
add bridge=pub-brg interface=ether1
set discover-interface-list=none
/interface l2tp-server server
set allow-fast-path=yes authentication=mschap2 default-profile=l2tp-loc \
    enabled=yes use-ipsec=required
add interface=loc-brg list=LAN
add interface=pub-brg list=WAN
add interface=lim-brg list=LIM
add interface=wif-brg list=LAN
add address=192.168.1.1/24 interface=loc-brg network=192.168.1.0
add address=10.10.10.1/24 interface=gst-brg network=10.10.10.0
add address=84.21.144.94/30 interface=ether2 network=84.21.144.92
add address=92.71.65.93/27 interface=ether1 network=92.71.65.64
add address=11.11.11.1/24 interface=wif-brg network=11.11.11.0
/ip dhcp-server lease
add address=11.11.11.13 client-id=1:DC:E9:94:4B:93:79 lease-time=1d \
    mac-address=DC:E9:94:4B:93:79 server=wifi-dhcp
add address=11.11.11.9 client-id=1:E0:2B:E9:29:B5:6E lease-time=1d \
    mac-address=E0:2B:E9:29:B5:6E server=wifi-dhcp
add address=11.11.11.11 client-id=1:10:02:B5:13:87:3 lease-time=1d \
    mac-address=10:02:B5:13:87:38 server=wifi-dhcp
add address=11.11.11.12 client-id=1:A0:D3:7A:85:48:8D lease-time=1d \
    mac-address=A0:D3:7A:85:48:8D server=wifi-dhcp
add address=11.11.11.10 client-id=1:AA:8F:7D:58:6A:9D lease-time=1d \
    mac-address=AA:8F:7D:58:6A:9D server=wifi-dhcp
add address=10.10.10.0/24 dns-server=8.8.8.8 gateway=10.10.10.1
add address=11.11.11.0/24 dns-server=8.8.8.8 gateway=11.11.11.1
add address=192.168.1.0/24 dns-server=8.8.8.8 gateway=192.168.1.1
set servers=8.8.8.8
/ip dns static
add address=192.168.1.1 name=router.lan
/ip firewall address-list
add address=192.168.1.241-192.168.1.243 list=shared
add address=216.218.206.0/25 list=novpn
add address=200.109.64.0/25 list=novpn
add action=accept chain=input connection-state=established,related,untracked
add action=drop chain=input connection-state=invalid
add action=accept chain=input dst-port=500,1701,4500 in-interface-list=WAN \
    log=yes log-prefix=vpn protocol=udp src-address-list=!novpn
add action=drop chain=input in-interface-list=!LAN
add action=fasttrack-connection chain=forward connection-state=\
    established,related
add action=accept chain=forward connection-state=\
add action=drop chain=forward connection-nat-state=!dstnat connection-state=\
    new in-interface-list=WAN
add action=drop chain=forward dst-address=!192.168.1.2 dst-address-list=\
    !shared in-interface=wif-brg out-interface=loc-brg
add action=drop chain=forward dst-address=!192.168.1.243 in-interface-list=\
    LIM out-interface-list=LAN
add action=drop chain=forward dst-address=!192.168.1.241 in-interface=\
    gst-brg out-interface=loc-brg
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=\
    WAN
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
add check-gateway=ping distance=1 gateway=92.71.65.65
add distance=2 gateway=84.21.144.93
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh address=192.168.1.0/24 port=202
set api disabled=yes
set winbox address=192.168.1.0/24,11.11.11.8/29
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/ppp secret
add name=usr profile=l2tp-loc service=l2tp
/system clock
set time-zone-autodetect=yes
/system identity
set name=Mikrotik1
/system logging
set 0 topics=info,!caps
set 1 action=error
add action=vpn topics=l2tp,!debug
add action=login topics=account
add topics=error
add action=firewall topics=firewall
/system ntp client
set enabled=yes primary-ntp=81.94.123.16 secondary-ntp=87.195.109.207
/system package update
set channel=long-term
/system routerboard settings
set auto-upgrade=yes
/system watchdog
set watchdog-timer=no
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
cAP AC:
# may/22/2022 13:14:33 by RouterOS 6.48.6
# model = RBcAPGi-5acD2nD
add name=bridge
/interface wireless
# managed by CAPsMAN
# channel: 2462/20/gn(14dBm), SSID: Office, CAPsMAN forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n frequency=auto installation=\
    indoor mode=ap-bridge ssid=MikroTik station-roaming=enabled \
    wireless-protocol=802.11 wps-mode=disabled
# channel: 5220/20-eeCe/ac/P(17dBm), SSID: Office, CAPsMAN forwarding
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40mhz-XX \
    frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik \
    station-roaming=enabled wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=ether1 ] rx-flow-control=auto tx-flow-control=auto
add name=WAN
add name=LAN
/snmp community
set 0 memory-lines=10000
set 1 disk-lines-per-file=10000
add disk-file-count=1 disk-file-name=log disk-lines-per-file=10000 name=file \
    target=disk
/user group
add name=user policy="telnet,read,winbox,!local,!ssh,!ftp,!reboot,!write,!poli\
    cy,!test,!password,!web,!sniff,!sensitive,!api,!romon,!dude,!tikapp"
add bridge=bridge disabled=yes interface=ether1
add bridge=bridge interface=ether2
add interface=ether1 list=WAN
add interface=bridge list=LAN
/interface wireless cap
set bridge=bridge caps-man-addresses=192.168.1.1 \
    caps-man-certificate-common-names=CAPsMAN-xxxxxxxxx caps-man-names=\
    Mikrotik1 certificate=request discovery-interfaces=bridge enabled=yes \
    interfaces=wlan1,wlan2 lock-to-caps-man=yes
add address=192.168.1.9/24 interface=ether1 network=192.168.1.0
/ip dhcp-client
set servers=8.8.8.8
add distance=1 gateway=192.168.1.1
/ip service
/snmp
set enabled=yes trap-community=snmp3 trap-interfaces=ether1 trap-target=\
    192.168.1.2 trap-version=3
/system clock
/system identity
set name=Mikrotik9
/system leds settings
set all-leds-off=immediate
/system logging
add action=file topics=system
/system ntp client
/system routerboard mode-button
set enabled=yes on-event=dark-mode
Only the best laptop doesn't suffer this problem (T14 Gen1), but i removed one of the caps from CAPsMAN and set it up as a normal AP, and there were no problems, so it is not related to laptops. Also recently I had problems setting up Outlook and synchronizing emails over wireless (20GB mailbox), so it is not the Share either.
I tried to pinpoint the problem with WireShark. Everything is fine for 30s then it starts renegotiating the session and it gets a ACCESS_DENIED for the file
(laptop is 11.11.11.11 and share is 192.168.1.243):
No.	Time	Source	Destination	Protocol	Length	Info
760914	89.589698	192.168.42.243	11.11.11.11	SMB2	1514	Read Response [TCP segment of a reassembled PDU]
760938	89.591271	11.11.11.11	192.168.42.243	SMB2	171	Read Request Len:1048576 Off:722468864 File: matlab\2k19a\MathWorks.MATLAB.R2019a.v9.6.Windows.x64.zip
761996	89.674764	192.168.42.243	11.11.11.11	SMB2	1514	Read Response [TCP segment of a reassembled PDU]
762031	89.676476	11.11.11.11	192.168.42.243	SMB2	171	Read Request Len:1048576 Off:723517440 File: matlab\2k19a\MathWorks.MATLAB.R2019a.v9.6.Windows.x64.zip
763099	89.751444	192.168.42.243	11.11.11.11	SMB2	1514	Read Response [TCP segment of a reassembled PDU]
763125	89.753683	11.11.11.11	192.168.42.243	SMB2	171	Read Request Len:1048576 Off:724566016 File: matlab\2k19a\MathWorks.MATLAB.R2019a.v9.6.Windows.x64.zip
764211	89.822781	192.168.42.243	11.11.11.11	SMB2	1514	Read Response [TCP segment of a reassembled PDU]
764229	89.824231	11.11.11.11	192.168.42.243	SMB2	171	Read Request Len:1048576 Off:725614592 File: matlab\2k19a\MathWorks.MATLAB.R2019a.v9.6.Windows.x64.zip
765316	89.89366	192.168.42.243	11.11.11.11	SMB2	1514	Read Response [TCP segment of a reassembled PDU]
765349	89.895204	11.11.11.11	192.168.42.243	SMB2	171	Read Request Len:1048576 Off:726663168 File: matlab\2k19a\MathWorks.MATLAB.R2019a.v9.6.Windows.x64.zip
766459	89.971326	192.168.42.243	11.11.11.11	SMB2	1514	Read Response [TCP segment of a reassembled PDU]
766490	89.973045	11.11.11.11	192.168.42.243	SMB2	171	Read Request Len:1048576 Off:727711744 File: matlab\2k19a\MathWorks.MATLAB.R2019a.v9.6.Windows.x64.zip
767562	90.048164	192.168.42.243	11.11.11.11	SMB2	1514	Read Response [TCP segment of a reassembled PDU]
767593	90.050371	11.11.11.11	192.168.42.243	SMB2	171	Read Request Len:1048576 Off:728760320 File: matlab\2k19a\MathWorks.MATLAB.R2019a.v9.6.Windows.x64.zip
768675	90.119783	192.168.42.243	11.11.11.11	SMB2	1514	Read Response [TCP segment of a reassembled PDU]
768680	90.12101	11.11.11.11	192.168.42.243	SMB2	171	Read Request Len:1048576 Off:729808896 File: matlab\2k19a\MathWorks.MATLAB.R2019a.v9.6.Windows.x64.zip
769785	90.190906	192.168.42.243	11.11.11.11	SMB2	1514	Read Response [TCP segment of a reassembled PDU]
769821	90.19254	11.11.11.11	192.168.42.243	SMB2	171	Read Request Len:1048576 Off:730857472 File: matlab\2k19a\MathWorks.MATLAB.R2019a.v9.6.Windows.x64.zip
(here the transfer drops to 0)
771147	151.631641	11.11.11.11	192.168.42.243	SMB2	310	Negotiate Protocol Request
771149	151.668820	192.168.42.243	11.11.11.11	SMB2	326	Negotiate Protocol Response
771150	151.669717	11.11.11.11	192.168.42.243	SMB2	220	Session Setup Request, NTLMSSP_NEGOTIATE
771151	151.670996	192.168.42.243	11.11.11.11	SMB2	291	Session Setup Response, Error: STATUS_MORE_PROCESSING_REQUIRED, NTLMSSP_CHALLENGE
771152	151.671798	11.11.11.11	192.168.42.243	SMB2	567	Session Setup Request, NTLMSSP_AUTH, User: .\user
771153	151.682111	192.168.42.243	11.11.11.11	SMB2	159	Session Setup Response
771154	151.682717	11.11.11.11	192.168.42.243	SMB2	180	Tree Connect Request Tree: \\192.168.42.243\Progs
771155	151.704473	192.168.42.243	11.11.11.11	SMB2	138	Tree Connect Response
771156	151.704637	11.11.11.11	192.168.42.243	SMB2	454	Create Request File: matlab\2k19a\MathWorks.MATLAB.R2019a.v9.6.Windows.x64.zip
771157	151.706819	192.168.42.243	11.11.11.11	SMB2	131	Create Response, Error: STATUS_ACCESS_DENIED
771161	151.883819	11.11.11.11	192.168.42.243	SMB2	234	Create Request File:
771162	151.896374	192.168.42.243	11.11.11.11	SMB2	298	Create Response File:
771163	151.896908	11.11.11.11	192.168.42.243	SMB2	451	Create Request File: ;GetInfo Request FS_INFO/FileFsVolumeInformation;GetInfo Request FS_INFO/FileFsAttributeInformation
771164	151.897909	192.168.42.243	11.11.11.11	SMB2	506	Create Response File: ;GetInfo Response;GetInfo Response
771165	151.898061	11.11.11.11	192.168.42.243	SMB2	146	Close Request File:
771166	151.89881	192.168.42.243	11.11.11.11	SMB2	182	Close Response
771167	151.899642	11.11.11.11	192.168.42.243	SMB2	382	Create Request File: matlab\2k19a
771168	151.901077	192.168.42.243	11.11.11.11	SMB2	298	Create Response File: matlab\2k19a
771169	151.901375	11.11.11.11	192.168.42.243	SMB2	260	Find Request File: matlab\2k19a SMB2_FIND_ID_BOTH_DIRECTORY_INFO Pattern: *;Find Request File: matlab\2k19a SMB2_FIND_ID_BOTH_DIRECTORY_INFO Pattern: *
771170	151.902303	192.168.42.243	11.11.11.11	SMB2	626	Find Response;Find Response, Error: STATUS_NO_MORE_FILES
771171	151.902426	11.11.11.11	192.168.42.243	SMB2	146	Close Request File: matlab\2k19a
771172	151.903198	192.168.42.243	11.11.11.11	SMB2	182	Close Response
771173	151.942841	11.11.11.11	192.168.42.243	SMB2	382	Create Request File: matlab\2k19a
771174	151.962573	192.168.42.243	11.11.11.11	SMB2	298	Create Response File: matlab\2k19a
771175	151.962933	11.11.11.11	192.168.42.243	SMB2	146	Close Request File: matlab\2k19a
771176	151.965256	192.168.42.243	11.11.11.11	SMB2	182	Close Response
771188	168.640501	11.11.11.11	192.168.42.243	SMB2	382	Create Request File: matlab\2k19a
771189	168.643298	192.168.42.243	11.11.11.11	SMB2	298	Create Response File: matlab\2k19a
771190	168.643661	11.11.11.11	192.168.42.243	SMB2	154	Notify Request File: matlab\2k19a
771191	168.644071	11.11.11.11	192.168.42.243	SMB2	322	Create Request File: matlab\2k19a;Notify Request
771192	168.644391	11.11.11.11	192.168.42.243	SMB2	374	Create Request File: matlab
771194	168.645188	192.168.42.243	11.11.11.11	SMB2	242	Create Response File: matlab\2k19a
771195	168.645365	192.168.42.243	11.11.11.11	SMB2	131	Notify Request File: matlab\2k19a
771197	168.645577	192.168.42.243	11.11.11.11	SMB2	298	Create Response File: matlab
771198	168.645919	11.11.11.11	192.168.42.243	SMB2	154	Notify Request File: matlab
771199	168.646315	11.11.11.11	192.168.42.243	SMB2	314	Create Request File: matlab;Notify Request
771200	168.646608	11.11.11.11	192.168.42.243	SMB2	366	Create Request File:
771201	168.646731	192.168.42.243	11.11.11.11	SMB2	131	Notify Response, Error: STATUS_PENDING
771203	168.647567	192.168.42.243	11.11.11.11	SMB2	242	Create Response File: matlab
771205	168.647911	192.168.42.243	11.11.11.11	SMB2	131	Notify Response, Error: STATUS_PENDING
771206	168.648303	192.168.42.243	11.11.11.11	SMB2	298	Create Response File:
771208	168.648647	11.11.11.11	192.168.42.243	SMB2	154	Notify Request File:
771209	168.648747	192.168.42.243	11.11.11.11	SMB2	131	Notify Response, Error: STATUS_PENDING
771210	168.649075	11.11.11.11	192.168.42.243	SMB2	306	Create Request File: ;Notify Request
771212	168.650037	192.168.42.243	11.11.11.11	SMB2	242	Create Response File:
771213	168.650277	192.168.42.243	11.11.11.11	SMB2	131	Notify Response, Error: STATUS_PENDING
771215	168.651128	192.168.42.243	11.11.11.11	SMB2	131	Notify Response, Error: STATUS_PENDING
771216	168.661214	11.11.11.11	192.168.42.243	SMB2	412	Create Request File: ;Find Request SMB2_FIND_ID_BOTH_DIRECTORY_INFO Pattern: *;Find Request SMB2_FIND_ID_BOTH_DIRECTORY_INFO Pattern: *
771228	168.686136	11.11.11.11	192.168.42.243	SMB2	146	Close Request File:
771229	168.687114	192.168.42.243	11.11.11.11	SMB2	182	Close Response
771230	168.687585	11.11.11.11	192.168.42.243	SMB2	420	Create Request File: matlab;Find Request SMB2_FIND_ID_BOTH_DIRECTORY_INFO Pattern: *;Find Request SMB2_FIND_ID_BOTH_DIRECTORY_INFO Pattern: *
771231	168.689075	192.168.42.243	11.11.11.11	SMB2	858	Create Response File: matlab;Find Response;Find Response, Error: STATUS_NO_MORE_FILES
771232	168.689257	11.11.11.11	192.168.42.243	SMB2	146	Close Request File: matlab
771233	168.690236	192.168.42.243	11.11.11.11	SMB2	182	Close Response
771319	204.667029	11.11.11.11	192.168.42.243	SMB2	174	Tree Connect Request Tree: \\192.168.42.243\Share
771320	204.667190	11.11.11.11	192.168.42.243	SMB2	382	Create Request File: Desktop.ini
771321	204.667575	11.11.11.11	192.168.42.243	SMB2	180	Tree Connect Request Tree: \\192.168.42.243\Pro
771322	204.672278	11.11.11.11	192.168.42.243	SMB2	210	Create Request File:
771326	204.688338	192.168.42.243	11.11.11.11	SMB2	138	Tree Connect Response
771327	204.688338	192.168.42.243	11.11.11.11	SMB2	131	Create Response, Error: STATUS_OBJECT_NAME_NOT_FOUND
771328	204.688338	192.168.42.243	11.11.11.11	SMB2	138	Tree Connect Response
771329	204.688338	192.168.42.243	11.11.11.11	SMB2	242	Create Response File:
771331	204.688519	11.11.11.11	192.168.42.243	SMB2	382	Create Request File: Desktop.ini
771333	204.688656	11.11.11.11	192.168.42.243	SMB2	382	Create Request File: Desktop.ini
771334	204.688783	11.11.11.11	192.168.42.243	SMB2	146	Close Request File:
771335	204.689464	11.11.11.11	192.168.42.243	SMB2	250	Create Request File: AutoRun.inf
771337	204.690032	192.168.42.243	11.11.11.11	SMB2	131	Create Response, Error: STATUS_OBJECT_NAME_NOT_FOUND
771338	204.690230	192.168.42.243	11.11.11.11	SMB2	131	Create Response, Error: STATUS_OBJECT_NAME_NOT_FOUND
771340	204.690411	192.168.42.243	11.11.11.11	SMB2	182	Close Response
771341	204.690618	192.168.42.243	11.11.11.11	SMB2	131	Create Response, Error: STATUS_OBJECT_NAME_NOT_FOUND
771343	204.690937	11.11.11.11	192.168.42.243	SMB2	250	Create Request File: AutoRun.inf
771344	204.691011	11.11.11.11	192.168.42.243	SMB2	250	Create Request File: AutoRun.inf
771345	204.692268	192.168.42.243	11.11.11.11	SMB2	131	Create Response, Error: STATUS_OBJECT_NAME_NOT_FOUND
771346	204.692432	192.168.42.243	11.11.11.11	SMB2	131	Create Response, Error: STATUS_OBJECT_NAME_NOT_FOUND
771350	205.366972	11.11.11.11	192.168.42.243	SMB2	234	Create Request File:
771351	205.426040	192.168.42.243	11.11.11.11	SMB2	298	Create Response File:
771352	205.429864	11.11.11.11	192.168.42.243	SMB2	234	Create Request File:
771353	205.431125	192.168.42.243	11.11.11.11	SMB2	298	Create Response File:
771354	205.462401	11.11.11.11	192.168.42.243	SMB2	294	Create Request File: matlab
771355	205.486319	192.168.42.243	11.11.11.11	SMB2	242	Create Response File: matlab
771356	205.486643	11.11.11.11	192.168.42.243	SMB2	260	Find Request File: matlab SMB2_FIND_ID_BOTH_DIRECTORY_INFO Pattern: *;Find Request File: matlab SMB2_FIND_ID_BOTH_DIRECTORY_INFO Pattern: *
771357	205.487693	192.168.42.243	11.11.11.11	SMB2	674	Find Response;Find Response, Error: STATUS_NO_MORE_FILES
771358	205.487859	11.11.11.11	192.168.42.243	SMB2	146	Close Request File: matlab
771359	205.488667	192.168.42.243	11.11.11.11	SMB2	182	Close Response
771367	205.757047	11.11.11.11	192.168.42.243	SMB2	260	Find Request SMB2_FIND_ID_BOTH_DIRECTORY_INFO Pattern: *;Find Request SMB2_FIND_ID_BOTH_DIRECTORY_INFO Pattern: *
771388	205.989121	11.11.11.11	192.168.42.243	SMB2	398	Create Request File: hwmonitor_1.35.zip
771391	205.990593	11.11.11.11	192.168.42.243	SMB2	406	Create Request File: AT-VGW-AMS_V230-Win.zip
771394	205.991264	192.168.42.243	11.11.11.11	SMB2	374	Create Response File: hwmonitor_1.35.zip
771395	205.991524	11.11.11.11	192.168.42.243	SMB2	162	GetInfo Request SEC_INFO/SMB2_SEC_INFO_00 File: hwmonitor_1.35.zip
771396	205.992072	192.168.42.243	11.11.11.11	SMB2	374	Create Response File: AT-VGW-AMS_V230-Win.zip
771397	205.992268	192.168.42.243	11.11.11.11	SMB2	131	GetInfo Response, Error: STATUS_ACCESS_DENIED
771399	205.992451	192.168.42.243	11.11.11.11	SMB2	131	GetInfo Response, Error: STATUS_ACCESS_DENIED
771400	205.992469	11.11.11.11	192.168.42.243	SMB2 	162	GetInfo Request SEC_INFO/SMB2_SEC_INFO_00 File: AT-VGW-AMS_V230-Win.zip
Do you notice something wrong with the configuration or has anyone encountered this problem before ?
Any help is appreciated
dadaniel
Re: Large share transfers (>100MB) drop over wifi with CAPsMAN
Sun May 22, 2022 8:37 pm
Enabling "Use IP firewall" in bridge settings solved this problem for us. Mikrotik support was not helpful: "Maybe packets moving slower and it works now"
anav
Does the problem occurred on a NORMAL setup of one of the capacs? In other words are you sure its capsman and not the capac wifi???
freemannnn
Forum Veteran
Forum Veteran
Sun May 22, 2022 9:08 pm
can you test file transfers with capsman in local forwarding mode?
or reset your cap with "/system reset-configuration caps-mode=yes" and test it with ONLY the default configuration maybe???
also i am not an expert in "proxy-arp" bridge setting? why is this used for? why you need this?
alfred998
Sun May 22, 2022 10:41 pm
There isn't much in the capac configuration as you can see, but I will try a reset next sunday as it is the only moment i can. It is not an hardware problem because it happens on both, and once you get them out of CAPsMAN there is no problem.
alfred998
Sun May 22, 2022 10:46 pm
proxy-arp is needed for vpn on the brigde you attach your connections to. iirc I have tried local forwarding mode, but I had problems with it. I will try again
anav
Sun May 22, 2022 11:00 pm
As the song goes ---> Be happy drop capsman :-)
Onix
Thu Oct 27, 2022 5:05 pm
hello! Maybe some update on this. The same for me... cant download larger ~100MB - it says network error. With wire everything is fine. Also use CapsMan no specific configuration. NO local forward... all goes via CAPSMAN meneger.
Any solutions?
bpwl
Thu Oct 27, 2022 5:44 pm
Not a CAPsMAN user, but interested in the technology, So I read a lot on this technology, that looks like it is probably just an RFC5415 implementation, with control via UDP 5246 and data via UDP 5247. CFR https://www.rfc-editor.org/rfc/rfc5415.html
From what I understand on RFC5415: there should be no difference between local AP config, and CAPsMAN config with local forwarding. The data-path and processing is local and looks the same, with no CAPsMAN involvement, except for the configuration and for some management tasks (like access-list and authentication).
Without local forwarding the data is transferred from the CAP to CAPsMAN via UDP 5247 , using the CAPWAP protocol, that has a small overhead, which could create extra fragmentation, handled by the CAPWAP protocol. But then I read this: relevant or not? I don't know!
Users browsing this forum: akakua, kormenator and 195 guests
