Kobe14
API command for hotspot state
Mon May 23, 2022 3:16 am
Hi, i googled and check the docs but i cant seem to find it.
What's the API command for querying hotspot state of a host?
e.g : Authenticated / Bypassed / dynamic/ DHCP / static
The CLI command is this but i'm sure it's not the same for API.
ip hotspot host print where authorized
mrz
Re: API command for hotspot state
Mon May 23, 2022 2:19 pm
You can read on how to use queries with examples here:
https://help.mikrotik.com/docs/display/ ... PI-Queries
Kobe14
Tue May 24, 2022 11:45 am
Thanks, but 2 things are still unclear
is this correct then?
/IP/hotspot/hosts/print
?type= X
?type=A or (authenticated?)
But the column name for hotspot status is blank (leftmost) so what should i put in "X" ?
Secondly i only see "print" and "set" is "count" not possible?
mrz
Tue May 24, 2022 11:55 am
You can do print and see what values API exactly returns, typically for flags it is either yes or no, so something like this should work:
/ip/hotspot/hosts/print
?authenticated=yes
Users browsing this forum: No registered users and 37 guests
