alv84
can't ping mikrotik IP
Mon May 23, 2022 10:45 am
hi everyone. please help on this.
i have set two non-public static IPs one on a cisco router and the other one on a mikrotik router with default configuration. the routers are directly connected to each other. now i can ping cisco from inside mikrotik but the vice versa fails. seems to be something in mikrotik default configuration. here is the mikrotik config:
# jan/02/1970 00:34:44 by RouterOS 6.44.5
# software id = 0G7Y-54W3
# model = 951Ui-2HnD
# serial number = B8570BE4F3C7
add admin-mac=C4:AD:34:82:55:8B auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=\
    MikroTik-82558F wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
add address=192.168.90.2/30 interface=ether1 network=192.168.90.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
    ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
    established,related,untracked disabled=yes
    invalid disabled=yes
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes \
    protocol=icmp
    disabled=yes in-interface-list=!LAN
    disabled=yes ipsec-policy=in,ipsec
    disabled=yes ipsec-policy=out,ipsec
    connection-state=established,related disabled=yes
    connection-state=invalid disabled=yes
    connection-state=new disabled=yes in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
/tool mac-server
/tool mac-server mac-winbox
by the way, i have disabled all NAT and firewall/masquerade rules.
kind regards.
tangent
Re: can't ping mikrotik IP
Mon May 23, 2022 10:55 am
It’s here:
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes protocol=icmp
Re-enable that.
alv84
Mon May 23, 2022 11:12 am
thank you dear tangent, but re-enabling that rule didn't help. still pinging mikrotik from cisco fails.
tangent
Mon May 23, 2022 11:53 am
You have a static IP and DHCP on ether1, which isn’t a member of the bridge. Unless the Cisco box is on that port, there’s no IP to ping.
Why are you mixing static and dynamic addressing anyway?
alv84
Mon May 23, 2022 12:01 pm
yes you're right. meanwhile i was correcting exactly the same thing. now dhcp server and the associated default ip pool are omitted. but again same result.
alv84
Tue May 24, 2022 9:54 am
i'm really frustrated on this. can someone help me here?? right now, the mikrotik router is reset with no default configuration and a static non-public /30 IP is set on ether1. on cisco side, another IPs of the same /30 range is set; say, 192.168.90.1/30 for cisco and 192.168.90.2/30 for mikrotik. i can ping cisco from inside mikrotik but pinging mikrotik from cisco fails.
i am really wondering why yhis happens? what am i missing in my routerboard?? please help!
regards.
alv84
Re: can't ping mikrotik IP  [SOLVED]
Tue May 24, 2022 11:33 am
this issue is over. i had mistakenly connected the patch cord to cisco isr management port which cannot forward traffic.
this topic is closed.
thanks.
Users browsing this forum: Bing [Bot], sebi099 and 40 guests
