VincentL
[SMS] Timestamp, system date and case sensitive
Mon May 23, 2022 1:50 pm
Hello All,
I'm very embarassed with a little thing :
I'd like to compare the SMS timestamp to date time, but TimeStamp is formatted like that : May/23/2022 and system clock is like that : may/23/2022.
I'm looking for a simple way to make it case insensitive.
I'm running ros7.
Could you help me with that ? Thank you
Vincent
rextended
Re: [SMS] Timestamp, system date and case sensitive
Mon May 23, 2022 1:53 pm
If for hypothesys the date have same format on both, how you compare them?
VincentL
Mon May 23, 2022 2:03 pm
Hello Rextended,
I was thinking of putting the current date and timestamp in variables then comparing them. It is not possible ?
Regards,
Vincent
rextended
Mon May 23, 2022 2:15 pm
I give you the soluction,
but first... paste this on terminal:
:global a "May/23/2022"
:global b "May/23/2022"
:if ($a <  $b) do={:put "$a <  $b"} else={:put "$a !<  $b"}
:if ($a <= $b) do={:put "$a <= $b"} else={:put "$a !<= $b"}
:if ($a =  $b) do={:put "$a =  $b"} else={:put "$a !=  $b"}
:if ($a >= $b) do={:put "$a >= $b"} else={:put "$a !>= $b"}
:if ($a >  $b) do={:put "$a >  $b"} else={:put "$a !>  $b"}
:if ($a != $b) do={:put "$a != $b"} else={:put "$a !!= $b"}
And see what is the problem....
rextended
Re: [SMS] Timestamp, system date and case sensitive  [SOLVED]
Mon May 23, 2022 2:26 pm
search tag # rextended date2int engdate2int
convert the string (May|may|MAY)/23/2022 to number 20220523 (the "date" type on RouterOS do not exist)
:global engdate2int do={
    :local input    [:tostr $1]
    :local intYear  ([:tonum [:pick $input 7 11]] * 10000)
    :local M ([:find "xxanebarprayunulugepctovecANEBARPRAYUNULUGEPCTOVEC" [:pick $input 1 3] -1] / 2); :if ($M>12) do={:set M ($M - 12)}
    :set   M ($M * 100)
    :local intDay   [:tonum [:pick $input 4 6]]
    :return ($intYear + $M + $intDay)
You can test it with:
:put [$engdate2int "may/23/2022"]
:global a [$engdate2int "May/23/2022"]
:global b [$engdate2int "may/23/2022"]
VincentL
Mon May 23, 2022 2:42 pm
Rextended,
Thank you so much for your help.
I even didn't know how to do a function for rOS.
I 'll study it and apply. I'm working on a script that ll send me a SMS when I' ll receive a warn from my provider.
Regards,
Vincent
VincentL
Mon May 23, 2022 2:44 pm
(And, I see, I can't compare strings)
rextended
Mon May 23, 2022 2:55 pm
Not quite exactly, you can just check if they are the same or different.
VincentL
Mon May 23, 2022 3:05 pm
Rextended,
I don't understand this line == :local intMonth ([:tonum ($arrMonths->[:pick $input 1 3])] * 100)
How does it works ?
Regards,
Vincent
VincentL
Mon May 23, 2022 3:19 pm
To be more precise, how does it $arrMonths find the correct value when $input 1 3 does not contains 3 characteres)
Vincent
rextended
Mon May 23, 2022 4:09 pm
neither the array... (j|J)an=1 (f|F)eb=2 (m|M)ar=3... ;)
VincentL
Mon May 23, 2022 6:34 pm
Thank you for your help and patience.
As it seems to be impossible to get only the timestamp from /tool/sms/inbox and compare to current date, I ll find another way to send me a SMS from my provider when he warn me that I'm over quota.
Regards,
Vincent
rextended
Mon May 23, 2022 6:43 pm
The timestamp is like "May/23/2022 17:42:43 GMT -0"
Some examples:
    :local arrMonths {an=1;eb=2;ar=3;pr=4;ay=5;un=6;ul=7;ug=8;ep=9;ct=10;ov=11;ec=12}
    :return ($intYear + $intMonth + $intDay)
:local timestamp "May/23/2022 17:42:43 GMT -0"
:local today [/sys clock get date]
:local intstamp [$engdate2int $timestamp]
:local inttoday [$engdate2int $today]
:put "today = $inttoday ; timestamp = $intstamp"
:if ( $inttoday      = $intstamp) do={ :put "SMS Sent today" }
:if (($inttoday - 1) = $intstamp) do={ :put "SMS Sent yesterday" }
:local searchtoday [:pick [/sys clock get date] 1 11]
/tool sms inbox
:foreach sms in=[find where timestamp~$searchtoday] do={
    :put "timestamp=$[get $sms timestamp] phone=$[get $sms phone] type=$[get $sms type] message=$[get $sms message]"
VincentL
Mon May 23, 2022 8:38 pm
@rextended,
It's just awesome !
I have a lot to learn, especially doing thing more simple.
I've read, understood and used both of your examples, and finally, the second fit perfectly to my needs.
For other people that fall in this thread :
:local phoneNumber "+XXyourPhoneNumber"
:local inMessage "SMS template to search"
:local outMessage "Quota Exceeded"
:local today [:pick [/sys clock get date] 1 11]
 /tool sms inbox
 : foreach sms in=[find where timestamp~$today and message~$inMessage] do={
  /tool/sms/send message=$outMessage phone-number=$phoneNumber lte1
XX is your local country indicative
Thank a lot again, it's great !
Vincent
Users browsing this forum: No registered users and 77 guests
