antwal
Wireless Wire nRAY 60G Link problems
Mon May 23, 2022 2:28 pm
Hello everyone,
I have a problem with the kit of these two antennas; theoretically they say it can reach a distance of 1500m, but already at 1300m I have no signal.
I updated the firmware to the latest version available, reset both antennas and reconfigured, but nothing to do they don't connect.
They are in open field without obstacles and yet at 1300m there is no connection; I tried to connect them closer by doing some tests; the connection is lost after 200m
how is this possible? Does the kit have a hardware problem?
Thanks in advance to everyone.
Rugx
Re: Wireless Wire nRAY 60G Link problems
Tue May 24, 2022 8:52 am
Try upgrading rOS version and set the highest available frequency.
antwal
Tue May 24, 2022 12:29 pm
rOS: 7.2.3
AP Bridge Frequency: 66960
No link at 1300m
Station Bridge Scan, finds nothing
Ca6ko
Long time Member
Long time Member
Tue May 24, 2022 2:01 pm
Channel 5 is not available in every country. Check the region settings on both devices, try setting a different channel frequency. If the devices are flashed for a specific region, re-flash via Netinstall.
antwal
Tue May 24, 2022 3:08 pm
I knew that channel 5 was not available for the EU but for some strange reason it allows you to select it
also I noticed this anomaly, without doing anything the antenna restarts automatically for a problem as you can see from the forwarding log the CPU is always between 24/26% after updating to 7.2.3
I will try to reinstall everything via netinstall and see if it solves the problem
Ca6ko
Long time Member
Long time Member
Tue May 24, 2022 3:30 pm
... for some strange reason it allows you to select it
It allows you to choose, but the power is greatly reduced.
I would not recommend using ROS7, use 6.48.6 LT
In some versions of ROS6, channel 6 was also available. This is the best channel for long range.
antwal
Tue May 24, 2022 10:22 pm
ok now they work, I tried at a higher distance bad performance is not the best; about 80/80 Mbps
Master:
             connected: yes
             frequency: 66000
        remote-address: DC:2C:6E:F2:08:D1
                tx-mcs: 1
           tx-phy-rate: 385.0Mbps
                signal: 30
                  rssi: -68
             tx-sector: 18
        tx-sector-info: left 0.8 degrees, down 0.2 degrees
              distance: 1835.26m
  tx-packet-error-rate: 9%
Slave:
             connected: yes
             frequency: 66000
        remote-address: DC:2C:6E:F1:FA:05
                tx-mcs: 2
           tx-phy-rate: 770.0Mbps
                signal: 50
                  rssi: -66
             tx-sector: 47
        tx-sector-info: left 0.4 degrees, up 0.4 degrees
              distance: 1835.24m
  tx-packet-error-rate: 0%
honzam
Tue May 24, 2022 11:34 pm
You wrote about 1300 meters. And in picture is 1835 meters. That's too much for nRAY. The first rain will disconnect it ....
Ca6ko
Long time Member
Long time Member
Wed May 25, 2022 10:50 am
You stubbornly do not use the standard Channel 4. The 66.0 GHz frequency is still channel 5. What results do you get on channel 4 of 64.8GHz?
The antennas are not precisely aligned. The parameters on the Master device are much worse than the Slave. Probably the installation rules are broken.
antwal
Wed May 25, 2022 11:14 am
it was initially 1300 meters, then it was moved to a higher building where the bridge is needed; otherwise I would do the extra 500 meters with another bridge
antwal
Wed May 25, 2022 11:16 am
I am doing a new alignment, I also try to change the channel and update you
Master:
             connected: yes
             frequency: 64800
                tx-mcs: 1
                signal: 20
                  rssi: -65
             tx-sector: 34
        tx-sector-info: right 0.6 degrees
              distance: 1835.27m
  tx-packet-error-rate: 15%
Slave:
             connected: yes
             frequency: 64800
                tx-mcs: 1
                signal: 35
                  rssi: -67
             tx-sector: 40
        tx-sector-info: up 0.2 degrees
              distance: 1835.32m
antwal
Wed Jun 15, 2022 3:05 pm
after various tests I realized that this type of antennas are not suitable for links over 500 meters; so I had to change the type of antennas
Users browsing this forum: No registered users and 48 guests
