baxenko
netwatch for two IPs
Mon May 23, 2022 4:08 pm
Hello. Unfortunately netwatch in Mikrotik can only ping one IP address. Therefore, I ask for help to write a script that will allow you to ping two IP addresses. If at least one of them is available, then disable the IP, if both are not available, then enable the IP.
I tried to do it but it doesn't work.
:local ipone "10.10.1.254";
:local iptwo "10.10.1.8";
:local pingsofone [ping $ipone count=3];
:local pingsoftwo [ping $iptwo count=3];
if (($pingsofone<1)&&($pingsoftwo<1)) do={/ip address enable [find comment="rezerv"];};
if (($pingsofone>1)||($pingsoftwo>1)) do={/ip address disable [find comment="rezerv"]}
rextended
Re: netwatch for two IPs  [SOLVED]
Mon May 23, 2022 4:50 pm
"if if" ?
ip address enabled [find comment=rezerv]
enabled ???
ip address disabled [find comment=rezerv]
disabled ???
You can not create script putting random words at random randomness...
:local ipone 10.10.1.254
:local iptwo 10.10.1.8
:if ( ($pingsofone < 1) and ($pingsoftwo < 1) ) do={
    /ip address  enable [find where comment="rezerv"]
:if ( ($pingsofone > 1) or  ($pingsoftwo > 1) ) do={
    /ip address disable [find where comment="rezerv"]
baxenko
Mon May 23, 2022 7:52 pm
there was a copy error
ty, Slava Ukraine!
rextended
Mon May 23, 2022 10:01 pm
ty, Slava Ukraine!
Users browsing this forum: No registered users and 37 guests
