ahmedakkaya
DHCP Leases
Mon May 23, 2022 4:17 pm
Hello
Leases time 01:00:00 defined as.
When the user leaves the network and comes back during the rental period, he gets a different ip.
What is the reason for this?
pe1chl
Re: DHCP Leases
Mon May 23, 2022 4:21 pm
Probably the user terminating the lease when they leave? And/or declining the lease when they re-apply.
When you want users to have a static IP, you need to make the lease static.
ahmedakkaya
Re: DHCP Leases
Mon May 23, 2022 4:32 pm
i am using hotspot, users due to ip change, they have to login again
memelchenkov
Re: DHCP Leases
Mon May 23, 2022 4:38 pm
You may use MAC cookie feature to avoid this: https://wiki.mikrotik.com/wiki/Manual:H ... MAC_Cookie
ahmedakkaya
Re: DHCP Leases
Mon May 23, 2022 4:41 pm
MAC cookie the feature is on and defined as 2 weeks and (14 days).
pe1chl
Re: DHCP Leases
Mon May 23, 2022 7:00 pm
Maybe the users change MAC address? Some devices do that to "hide them from tracking".
rextended
Re: DHCP Leases
Mon May 23, 2022 7:02 pm
Is the new default on devices, change client MAC for each AP MAC.
And must re-authenticate everytime.
¯\_(ツ)_/¯
It is the client's choice not to be tracked, so it is not tracked between one AP and another, also if have same SSID...
And everytime log in again... :twisted:
pe1chl
Re: DHCP Leases
Mon May 23, 2022 7:13 pm
Fortunately I do not see that yet on my work network. Usually they change MAC only for each SSID.
Maybe it is different on networks that provide a logon portal page, we don't have that (no "hotspot").
rextended
Re: DHCP Leases
Mon May 23, 2022 7:19 pm
If I were to write what I think of those geniuses who invent "for us and for our privacy" these breakups of... (like also ESNI on TLS 1.3, DoH and others, but not DoT)
I would have to ban myself from the forum...
ahmedakkaya
Re: DHCP Leases
Mon May 23, 2022 11:59 pm
same mac address but different ip
ahmedakkaya
Re: DHCP Leases
Tue May 24, 2022 12:08 am
settings like this
pe1chl
Re: DHCP Leases
Tue May 24, 2022 11:14 am
You will have to debug this locally. It is not a problem I see (both on v6 and v7 RouterOS).
Make a packet capture of the DHCP traffic and analyze it using Wireshark to see what is really happening.
rextended
Re: DHCP Leases
Tue May 24, 2022 12:03 pm
From your screenshot I see something strange...
What is your RouterOS version and what RouterBOARD is?
Post the results of
/export file=config
on forum, removing first serial number, usernames, passwords and emails
ahmedakkaya
Re: DHCP Leases
Tue May 24, 2022 12:25 pm
Post the results of
/export file=config
ahmedakkaya
Re: DHCP Leases
Tue May 24, 2022 12:27 pm
I have no knowledge of Wireshark?
pe1chl
Re: DHCP Leases
Tue May 24, 2022 12:36 pm
Then you need to hire someone who does... or live with the issue.
ahmedakkaya
Re: DHCP Leases
Tue May 24, 2022 12:47 pm
good answer :)
rextended
Re: DHCP Leases
Tue May 24, 2022 1:18 pm
Post the results of
/export file=config
I have the confirm, you migrated from very old RouterOS version to 6.49.6, with all the consequences on configuration.
I have also requested you the export, but ignoring that, my guess game end here.
pseu01
Re: DHCP Leases
Sat Jun 11, 2022 11:37 am
good answer :)
Ahmed, I have the same problem, has anyone found a solution?
Users browsing this forum: Fi011, Google [Bot], Mikuser17, quantum666, shahzaddj1 and 183 guests
