mikroticker
Port2 link-speed limited to 100 Mbps on hAP ac
Mon May 23, 2022 4:45 pm
On my hAP ac (RouterOS 7.2.3) i got a gigabit ethernet switch connected to ethernet port 2.
The issue is, that the maximum link speed is limited to 100 Mbps/FD only.
On all other ethernet ports i get 1Gbps
When i manually set the link-speed to 1Gbps i get no link at all.
Ethernet ports 2..5 are all on one bridge - nothing special.
Tested different cables (CAT6, CAT5e) without change.
Tested different link-partners (switch, PC) without change.
Any idea what can cause this limitation?
rextended
Re: Port2 link-speed limited to 100 Mbps on hAP ac
Mon May 23, 2022 5:04 pm
Post the result of
/interface ethernet export
except serial number (do not worry for MACs, if any)
mikroticker
Mon May 23, 2022 5:22 pm
[admin@MikroTik] > /interface ethernet export
# may/23/2022 16:21:47 by RouterOS 7.2.3
# software id = MZQ3-CBTY
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = xxxxxxxxxxx
set [ find default-name=ether1 ] name=ether1_WAN speed=10Mbps
set [ find default-name=ether2 ] name=ether2_SWITCH
set [ find default-name=sfp1 ] disabled=yes
[admin@MikroTik] >
At the moment only port1 and port2 are in use.
Another question... what does this "speed=10Mbps" mean?
rextended
Mon May 23, 2022 5:24 pm
Someone at set it to 10Mbps when auto is off
Paste this on terminal, if the port not works, probably is broken:
set [ find ] speed=1Gbps
mikroticker
Mon May 23, 2022 5:36 pm
Entering the commands does not return anything?
I did a test and manually set the link-speed on port 1 to 1Gpbs.
It was not possible to get a link then! (Altough autonegotiation previously established a 1Gbps/FD link)
rextended
Mon May 23, 2022 5:38 pm
Not all device support non-auto negotiation
results of
 /int eth monitor [find] once
mikroticker
Mon May 23, 2022 5:40 pm
[admin@MikroTik] /interface/ethernet> /int eth monitor [find] once
                        name: ether1_WAN ether2_SWITCH ether3     ether4     ether5     sfp1
                      status: link-ok    link-ok       no-link    no-link    no-link    no-link
            auto-negotiation: done       done          done       done       done       failed
                        rate: 1Gbps      100Mbps
                 full-duplex: yes        yes
             tx-flow-control: no         no
             rx-flow-control: no         no
                 advertising: 10M-half   10M-half      10M-half   10M-half   10M-half
                              10M-full   10M-full      10M-full   10M-full   10M-full
                              100M-half  100M-half     100M-half  100M-half  100M-half
                              100M-full  100M-full     100M-full  100M-full  100M-full
                              1000M-half 1000M-half    1000M-half 1000M-half 1000M-half
                              1000M-full 1000M-full    1000M-full 1000M-full 1000M-full
    link-partner-advertising: 10M-half   10M-half
                              10M-full   10M-full
                              100M-half  100M-half
                              100M-full  100M-full
                              1000M-half
                              1000M-full
          sfp-module-present:                                                           no
             sfp-vendor-name:
      sfp-vendor-part-number:
         sfp-vendor-revision:
           sfp-vendor-serial:
      sfp-manufacturing-date:
rextended
Mon May 23, 2022 5:43 pm
the problem is in the other side: do not support or do not advertise more than 100Mbps...
mikroticker
Mon May 23, 2022 5:49 pm
I thought that too but i then tried different link partners and they all connect successfully with 1Gbps on the other ports of the router.
It's just port 2 that refuses to report the 1Gbps client capability.
Here is the result when using port3 instead of port2:
                      status: link-ok    no-link       link-ok    no-link    no-link    no-link
                        rate: 1Gbps                    1Gbps
                              10M-full                 10M-full
                              100M-half                100M-half
                              100M-full                100M-full
                              1000M-half               1000M-full
                              1000M-full
             sfp-vendor-name:
           sfp-vendor-serial:
rextended
Mon May 23, 2022 5:54 pm
If is the same cable moved from ether2 to ether3, or one pin is bent or oxydized, or the port is broken
mikroticker
Mon May 23, 2022 6:42 pm
Inspected the pins and cleaned them with IPA - they are looking perfect.
Additionally opened the device to check the solder joints - looking perfect aswell.
By the way... these hAP ac devices are running damn hot!
mikroticker
Mon May 23, 2022 6:44 pm
What i also don't understand is why on port 3 the option "1000M-half" is missing?
rextended
Mon May 23, 2022 6:56 pm
Not all devices supports 1000M-half.
Personally I think is a non-sense 1G half....
mikroticker
Re: Port2 link-speed limited to 100 Mbps on hAP ac  [SOLVED]
Mon May 23, 2022 7:05 pm
Ok, so most likely the hardware of port 2 is somehow damaged?
rextended
Mon May 23, 2022 7:07 pm
Apparently...
mikroticker
Mon May 23, 2022 7:21 pm
Thank you for your help! :)
mikroticker
Tue May 24, 2022 8:26 pm
Just a quick update...
I used the "Cable test" function on the suspicious ethernet port 2 and it shows me a short on the last two wire-pairs.
This confirms that there is a hardware defect on the two additional pairs used by gigabit ethernet.
Forther investigation showed, that unfortunately there is no ESD-protection on ports 2...4 so the ethernet switch chip is definately faulty.
Users browsing this forum: Google [Bot], GoogleOther [Bot], vingjfg and 170 guests
