aboshhab
Are there any limitation in number of interface lists ?
Mon May 23, 2022 9:15 pm
Hello there!
I have Cloud Server (CHR RouterOS 7.2.3),
I have 239 interface lists, when I try to add another one my server appears with an error, interrupted, and suddenly reboots.
is there any limitation in the number of interface lists?
Jotne
Re: Are there any limitation in number of interface lists ?
Mon May 23, 2022 9:56 pm
How many interfaces do you have since you need more than 200 interface lists?
rextended
Mon May 23, 2022 11:02 pm
Why do you need a list of interfaces for each individual interface, with only one interface inside?
aboshhab
Mon May 23, 2022 11:59 pm
I use them for a Dynamic interface with VRF for each Profile
aboshhab
Tue May 24, 2022 12:02 am
I use them for a Dynamic interface with VRF for each Profile...
Jotne
Tue May 24, 2022 12:14 am
PS no need to make two post about the same. You can do many quote in one post.
Still does not understand what is your goal is. Is the some in production, or just for test?
Make a design drawing.
Sob
Tue May 24, 2022 12:52 am
Regardless of what the goal is, and even if it may be possibly wrong, adding too many lists shouldn't cause reboot (and yes, my quick test says that it does happen). That's clearly a bug. I don't know if there's supposed to be some limit or not, it doesn't seem documented anywhere. So if you need it, contact support and let them clarify how it should be and do something with it.
aboshhab
Tue May 24, 2022 1:13 am
I'm sorry
this is a VPN server to bridge multiple sites over SSTP connection, every interface list with many VPN client interfaces for one VRF list to be isolated from other customers
I don't know if this is the best way ...
thanks a lot
Sob
Tue May 24, 2022 2:55 am
I mean, isn't it obvious? The command for rebooting router is /system/reboot. If anything else (not counting update) reboots router, it can't be right. :)
But it doesn't mean that you'll get good news from support, it's possible that there's supposed to be a limit and they just forgot to add a check and error message. Ask them and you'll see.
Jotne
Tue May 24, 2022 7:57 am
Is this some you have in production, or some you like to setup? Can you post the config?
Users browsing this forum: Bing [Bot], derolf, K0NCTANT1N, natxo, nizce and 57 guests
