Beerbellyberry132
CAPsMAN wont work with second bride network.
Tue May 24, 2022 2:52 am
I'm having a issue with making 2 bridge networks with capsman. One of the Wi-Fi networks works fine "Public" but the other wont work. If i try to connect to network it automatically reboots wap
erlinden
Re: CAPsMAN wont work with second bride network.
Tue May 24, 2022 10:30 am
Why do you use two bridges? VLAN is mostly used to (virtually) seperate LAN's.
Instead of sharing a backup, you better share the config (/export hide-sensitive file=anynameyoulike). Make sure to remove any private information.
anav
Tue May 24, 2022 2:20 pm
Stick to one thread please (not his one).
Follow this thread here ----- viewtopic.php?t=186214
Users browsing this forum: Google [Bot], jhbarrantes, kokoboko, pstrauts, sinaaram, stef70, VictorS, xrlls and 64 guests
