pap169
IP Range Extend
Tue May 24, 2022 5:01 am
I am a newbie on Mikrotik routers and I want some help. The situation is this. I want to expand the ip range (IPV4) on dhcp network to /23. I have put on IP-> DHCP Server>Networks on Address /23 and on Pool 192.168.0.10-192.168.1.254 (example 192.168.0,0/23 but the leases are still on /24 subnet (254 IP range). I can not figure what I am doing wrong. A little help would be appreciated.
kevinds
Long time Member
Long time Member
Re: IP Range Extend
Wed Jun 01, 2022 10:33 pm
You need to make more changes..
IP Addresses and Firewall for example.
mkx
Re: IP Range Extend
Wed Jun 01, 2022 11:00 pm
Agree with @kevinds that you need to verify that new subnet mask length is configured everywhere where needed.
As to IP address assignment: devices which are part of network, will try to extend DHCP lease of already used IP address and DHCP server will try to grant that. Only devices without valid lease will receive new leases from the extended address pool. Whether those will be from the lower (old) part or higher (new) part depends on how many addresses from pool are occupied and on the pool allocation strategy (some servers allocate addresses from lower end of pool, I don't remember what strategy is used by MT DHCP server). So it might take a while before you see used addresses from the pool extension.
aesmith
Re: IP Range Extend
Fri Jun 03, 2022 3:04 pm
Have you also changed the subnet mask on the interface routing to 192.168.0.0/23 ?
pap169
Re: IP Range Extend
Sun Jun 05, 2022 7:47 am
Thank you for your responses. I have done everything correct is working. But only one issue I have, when a device is new get a lease 192.168.0.255 is not having internet connection. How to disable the .255 to not forward this lease.
Also on IP Pool what is the correct scenario? To extend the IP range (example 192.168.0.10-192.168.1.254) or to create a second pool with (example one pool with this 192.168.0.10-254 and one with 192.168.1.2-200 with the next pool enabled on Winbox)?
@kevinds on IP adresses I have put 192.168.0.1/23 on Address and network 192.168.0.0 is that correct?
Regards.
Buckeye
Forum Veteran
Forum Veteran
Re: IP Range Extend
Sun Jun 05, 2022 7:55 am
What is the dhcp client? As long as it obtained a lease for 192.168.0.255/23 that should be a valid usable address and likewise 192.168.1.0/23 should be a valid usable address as well.
If it is a windows client, can you post output of
ipconfig /all
pap169
Re: IP Range Extend
Sun Jun 05, 2022 8:10 am
It is obtained from Android device and it cause problems like no internet. On Windows/Linux not having an issue so far.
kevinds
Long time Member
Long time Member
Re: IP Range Extend
Sun Jun 05, 2022 10:58 am
Regards.
Both pools are valid.
If you just want have 192.168.0.255 not to be given out, could static assign it to a device that will never connect, MAC address 11:11:11:11:11:11 for example, or use two pools.
Yes, the IP address 192.168.0.1/23 would be correct. Make sure you have also adjusted the Firewall NAT rule as well.
pap169
Re: IP Range Extend
Sun Jun 05, 2022 12:30 pm
Ok I understand about the pools. On Firewall NAT what rule would exactly should be customize?
Regards.
kevinds
Long time Member
Long time Member
Re: IP Range Extend
Sun Jun 05, 2022 12:42 pm
Regards.
The mascaraed rule.. Default was 192.168.88.0/24? Would need to be adjusted to /23 as well.
rextended
Re: IP Range Extend
Sun Jun 05, 2022 7:19 pm
Regards.
Post your config on forum, is mostly rapid than ask continuosly what and where.
export with /export command, but remove sensible data from the config before posting it on forum (serial number, email, username and passwords)
If you want using 192.168.0.10-192.168.1.254
you must set two address interval inside the pool:
192.168.0.10-192.168.0.254 and 192.168.1.1-192.168.1.254
Some OS do not like IPs (even if are perfectly valids) than end with .0 or with .255
And I not mean 192.168.0.0 and 192.168.1.255 (than are invalid for other reason) but 192.168.0.255 and 192.168.1.0
pap169
Re: IP Range Extend
Sun Jun 05, 2022 10:29 pm
Ok here is the export:
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=Pool2 ranges=192.168.1.1-192.168.1.254
add name=dhcp next-pool=Pool2 ranges=192.168.0.10-192.168.0.254
add address-pool=dhcp disabled=no insert-queue-before=bottom interface=bridge lease-time=1h name=defconf
add address=192.168.0.1/23 comment=defconf interface=bridge network=192.168.0.0
add address=192.56.10.1/24 interface=ether1 network=192.56.10.0
/ip dhcp-client
/ip dhcp-server config
set store-leases-disk=never
add address=192.168.0.0/23 comment=defconf dns-server=192.168.0.1 gateway=192.168.0.1 netmask=23
set allow-remote-requests=yes servers=192.56.10.1
/ip dns static
add address=192.168.0.1 comment=defconf name="Test1"
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked disabled=yes
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes protocol=icmp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" disabled=yes dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy" disabled=yes ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" disabled=yes ipsec-policy=out,ipsec
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=established,related,untracked disabled=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add distance=1 gateway=192.56.10.1
@kevinds on NAT there was nothing related to /24
@rextended Please take a look I have configured with 2 pools
Thank you guys.
mkx
Re: IP Range Extend
Mon Jun 06, 2022 8:16 am
I'm not sure that it's OK to use own IP address as default gateway ... you should be using your upstream gateway ... or, if that IP address actually belongs to upstream gateway, you should assign ether1 different IP address.
The rest looks fine to me.
pap169
Re: IP Range Extend
Sat Jun 11, 2022 6:56 am
It is under test so far that is the reason that is configured like this way. I think the same for the rest that are ok.
Thank you for your response.
Users browsing this forum: BioMax, reinerotto and 30 guests
