HunterKE
Remotely Access Static IP without DHCP
Tue May 24, 2022 2:43 pm
I have a simple network setup of 3 PowerBeam 5AC connected to a Mikrotik RB2011.
The Powerbeams are APs to serve other locations. I have set up the router to have bridge 1 and 2. Bridge one has a DHCP server 192.168.1.0/24. Bridge 2 has no DHCP because the clients connect using PPPoE accounts. Each of the Powerbeams has two LiteBeam M5 Stations connected. On the router one powerbeam is connected to bridge 1, the other two on bridge 2. All the Radios (APs and STs) are configured using static IPs( 192.168.1.10-192.168.1.50).
I have setup L2TP on the Mikrotik Router for remote access. The problem here is that I can only remotely access the radios on Bridge 1. Bridge 2 I'm getting the error, Site cannot be Reached.
How will I make devices on bridge 2 accessible remotely over L2TP without adding a DHCP server for bridge 2?
kevinds
Long time Member
Long time Member
Re: Remotely Access Static IP without DHCP
Wed May 25, 2022 7:50 pm
Static IPs?
Which devices? The clients? Or the radios?
Your post really doesn't make sense..
If you want to access the clients, use the IP from the PPPoE connections?
Users browsing this forum: No registered users and 202 guests
