mkamenjak
User manager 7 Authorization into Cisco Nexus switches.
Tue May 24, 2022 9:31 pm
Hello, I have user manager v.7.2.3.
And I want to use it purely as a RADIUS authentication server to manage my network devices. Nothing fancy like hotspot or CRM etc...
And I have a lot of Cisco Nexus switches in my core. Excellent switches I must admit.
Also I like so far how user-manager works. Much better than our previous freeradius/LDAP contraption that we have previously experimented with. How do I get Mikrotik User-manager to work nicely together with Cisco NXOS?
However I am having trouble using user-manager with our Nexus switches. I can authenticate to the switch, but it is hard coded to give me write only 'network-operator' privileges instead of 'network-admin' privileges by default. And I need 'network-admin' privileges(or 'full' privileges in Mikrotik terms). As far as I know there is no way to chenge this default. However it is possible to get those privileges by pushing a RADIUS attribute. The RADIUS attribute is supposed to be called 'Cisco-AVPair', I think?
So far I have configured it like this(attachment picture 1). I don't know if this is correct, can you help? Code:
/user-manager attribute
add name=Cisco-AVPair type-id=26 value-type=string vendor-id=Cisco
And I have configured the RADIUS user like this, obviously redacted:
/user-manager user
add attributes="Cisco-AVPair:= \"shell:roles*\\\"network-admin vdc-admin\\\"\"" name=XYZ shared-users=unlimited
Picture 2 in the attachemnt is this... Also I don't know if this part is correct either.
EDIT, My radius configuration on my test Nexus switch:
radius-server host 1.1.1.1 key 7 "somekey" authentication accounting timeout 1
radius-server host 8.8.8.8 key 7 "somekey" authentication accounting
radius-server directed-request
aaa group server radius RADIUS
    server 1.1.1.1
    server 8.8.8.8
aaa authentication login default fallback error local
aaa authentication login default group RADIUS
sktop
Re: User manager 7 Authorization into Cisco Nexus switches.
Tue Sep 27, 2022 3:44 pm
/user-manager user
    server 1.1.1.1
    server 8.8.8.8
Did You manage to get it working, could You please share final config?
Is this issue related only to the Nexus switches?
I am thinking to use User Manager as Radius authentication server for CISCO switches (I do not have Nexus, just 2960, 1100 Catalyst series).
I thought it will work when I set up User Manager with ROS7 and just add some users.
Users browsing this forum: No registered users and 21 guests
