eldoncito2019
Using "do and else" in script.
Tue May 24, 2022 9:44 pm
I'm trying to make a script that does the following: before 18:00:00, it tells me "get ready for dinner" between 18:00:00 and 19:00:00, it tells me "it's dinner time" "and that after 19:00:00, it tells me "to rest dinner", is this possible, here is my script:
:local time [/system clock get time]
:if ($time <= "18:00:00" || $time => "19:00:00") do={:put "get ready for dinner"} else={:put "it's dinner time"}  XXX={:put "to rest dinner"}
EL DONCITO
rextended
Re: Using "do and else" in script.
Tue May 24, 2022 10:46 pm
read your own phrase and simply convert it on 3 :if
:if before 18:00:00, do= tells me "get ready for dinner"
:if between 18:00:00 and 19:00:00, do= tells me "it's dinner time"
:if after 19:00:00, do= tells me "to rest dinner"
pe1chl
Tue May 24, 2022 10:54 pm
It is possible to do it with 2 if-statements, 3 are not required. But it isn't possible with 1 if-statement, that is clear.
rextended
Tue May 24, 2022 10:55 pm
@pe1chl
It is better to learn to walk first, then to ride a bicycle... :roll:
eldoncito2019
Tue May 24, 2022 11:58 pm
It will be like this with 2 if:
:if ($time <= "18:00:00" || $time = "19:00:00") do={:put "get ready for dinner"} else={:put "it's dinner time"}
:if ($time  > "19:00:00") do={:put ("to rest dinner"}
EL DONCITO
nichky
Wed May 25, 2022 12:13 am
i'm really want to know, where you going to use this script?
eldoncito2019
Wed May 25, 2022 12:20 am
I'm slowly learning to use the functions, just that, but the script doesn't work if I run it every second.
Can you help me, here is the script:
:global stopRouterRun false
:do {
:if ($time < "17:14:00" || $time = "17:14:10") do={:put "get ready for dinner"} else={:put "it's dinner time"}
:if ($time  > "17:14:10") do={:put "to rest dinner"}
   :delay 1s
} while=(!$stopRouterRun)
EL DONCITO.
pe1chl
Wed May 25, 2022 1:07 am
That is not correct, and also too complicated. In each if statement you need to make only 1 time compare, and use the do and else branch.
rextended
Wed May 25, 2022 2:36 am
@eldoncito2019, ignore @pe1chl (I'm not saying he doesn't say the right things, but it's early for you)
I know you're a beginner (no offense, of course) and until you learn the simple things first, forget about the slightly more complex ones ...
Ignore "else" and follow my already provided hint...
But haven't you noticed that your calculations are absurd?
You split day time on 2 parts: from 18:00 to 19:00 for dinner, and from 19:01 to 17:59 for NOT dinner.
02:00 is both after 18:00 and before 19:00
You mean midnight for split the time on 3 parts?
At that point you have 3 time intervals: 00:00 to 17:59 for "get ready for dinner", 18:00 to 19:00 for "dinner time", and from 19:01 to 23:59 for "rest dinner".
But if you want go over midnigth for "rest dinner" you put on play more complex conditions...
Ignoring the logic, but for just make one example, with only 2 "if", without any "else":
:local message "after dinner"
:if ($time >= 18:00:00 and $time <= 19:00:00) do={:set message "dinner time"}
:if ($time > 19:00:00) do={:set message "before dinner"}
:put $message
eldoncito2019
Re: Using "do and else" in script.  [SOLVED]
Wed May 25, 2022 4:24 am
:do {
    :local message ("$time after dinner")
    :if ($time >= 21:22:00 and $time <= 21:22:10) do={:set message ("$time dinner time")}
    :if ($time > "21:22:10") do={:set message ("$time before dinner")}
    :put $message
    :delay 1s
Thank you REX.
EL DONCITO.
eldoncito2019
Wed May 25, 2022 5:24 pm
Very good REX, I'm learning about script, and if I just want the script to run like this:
:do {
    :if ($time >= 12:00:00 and $time <= 12:30:00) do={:set message ("$time dinner time")}
    :put $message
    :delay 1s
EL DONCITO.
eldoncito2019
Wed May 25, 2022 5:41 pm
I solved it like this
I hope you are well:
:do {
    :if ($time >= 18:31:00 and $time <= 18:31:10) do={:put ("$time dinner time")}
    :delay 1s
But I have another question, how do I do it in the terminal so that the script does not continue running. Thank you.
EL DONCITO
msatter
Wed May 25, 2022 6:55 pm
Currently, the mode of transportation is clearly still a push buggy. :lol:
eldoncito2019
Wed May 25, 2022 7:54 pm
I do not understand. LOL :?
EL DONCITO.
rextended
Wed May 25, 2022 8:25 pm
Remove
:do
:put $message
:delay 1s
Users browsing this forum: No registered users and 38 guests
