wwitte002
R11e-LTE not working after firmware upgrade
Wed May 25, 2022 10:06 am
Hi forum
I updated the MikroTik router to the latest RouterOs to version 7.2.3 the LTE is no longer connecting and i'm presented with several "blocks" that I cannot seem to understand to get the router working:
a) On the quick setup page, when i opt to check for an update the error is: ERROR: could not resolve DNS name. On the LTE settings, same as b below.
b) Interface: LTE: a new version exists, but clicking Upgrade result in : Couldnt Start - Device must be in running state; The firmware version is MikroTik_CP_2.160.000_v012
Searching the forums for these errors are not too helpful as it seems to be different causes that results in the same error.
Ps - I am also a beginner as the Forum suggests, sometimes the pro's reply with a lot of technical instructions, please try and be specific?
Thanks a lot.
rextended
Re: R11e-LTE not working after firmware upgrade
Wed May 25, 2022 10:14 am
It seems that you have read the forum,
so you should know that you have to provide details and that you are initially asked how the device is configured.
You have not provided the rest of the details and the configuration, other than the name of the LTE module and the version of RouterOS.
wwitte002
Wed May 25, 2022 10:17 am
i tried searching the forums, havent read them all. Can you help me do that?
rextended
Wed May 25, 2022 10:22 am
I've already started trying to help you, but if you don't read what I wrote...
wwitte002
Wed May 25, 2022 10:31 am
SiB
Sat May 28, 2022 12:58 am
Hmm, new RouterOS v7 for some lte modems say not true about firmware version. Your 012 version is old and yes they are a newer version and to do a firmware upgrade you must first connect it to internet to do it, by lte itself !.
Please not give us a QuickSet. If you not familiar with Terminal and export command then please read a documentation at https://help.mikrotik.com/docs/display/ROS/LTE .
First do a connection with proper APN, uncheck the "Use Network APN" and get infernet from LTE first.
Next step will be to do a firmware upgrade. Not all stuff at ones.
BlackRat
Thu Aug 25, 2022 9:43 pm
Mikrotik RBD53GR-5HacD2HnD, updated to latest modem firmware first (Router firmware was 6.49.4).
Then upgraded router to 7.4.1.
Now LTE not working.
Thinking of Netinstall to 6.49.6...
Modem is appearing for a seconds, then disappear.
BlackRat
Fri Aug 26, 2022 12:02 pm
Hmm.. After Netinstall (now 6.49.6) problem exists.
BlackRat
Fri Aug 26, 2022 12:05 pm
When R11e-LTE6 found it didn't have serial number... Now what I should to do to revert normal operation?
BlackRat
Fri Aug 26, 2022 1:24 pm
Downgraded to factory firmware (6.46.4) - problem still exists...
hecatae
Fri Aug 26, 2022 10:51 pm
Did you upgrade routerboard firmware as well as RouterOS?
Beginner
Mon Dec 18, 2023 9:55 pm
It is happening the same with me. Did anyone found the solution? Thanks
Users browsing this forum: Buechi, jaclaz, mtkvvv, trmns and 65 guests
