Caci99
Spam autodetect
Thu Sep 20, 2007 3:11 pm
There is a link in the wiki of how to autodetect spammers:
http://wiki.mikrotik.com/wiki/How_to_de ... MTP_output
Well, I tried that, and today I had the chance to verify if it is working and unfortunately it didn't. Our mail server got full within minutes with more than thousands of mail. When I saw that I did a torch on port 25 to see which IP was spamming. Once identified the external IP I dropped it with a firewall rule.
This way I stoped the spamming proccess.
Can anyone improve the above example?
Thanks Toni
dentwistle
Re: Spam autodetect
Fri Sep 21, 2007 12:57 am
I have used that method for detecting infected computers on my network. The values that they are using are a little high I would change the connection-limit to 5,32 what that means is that any one IP address can open at most 5 smtp connections at any one time. I didn't bother with the connection rate because most mail spamming programs try to open multiple smtp connections at once. These settings have proven invaluable in detecting workstation infections but might need to be tweeked for use with a server.
Caci99
Re: Spam autodetect
Fri Sep 21, 2007 11:02 am
I have noticed that the external IP spaming me yesterday wasn't opening more than two connections at a time, it was using small emails (around 15kb) and sending aproximatly 10 email at once in interval of nearly 10 sec.
On the other hand the mail server inside the LAN does of course use more connections and more data rate. So I exluded the mail server to be proceded through that rule, and let's see how it will work.
kvan64
Re: Spam autodetect
Sun Oct 14, 2007 10:59 am
The firewall rules are ok but the script appears "invalid" in my script list.
Caci99
Re: Spam autodetect
Mon Oct 15, 2007 11:04 am
I haven't adapted the script, because I am more focused to see the firewall rule is working.
Is there any spam tool to test it, thus tuning it to my LAN specification?
-Toni-
Don't crash the ambulance, whatever you do
kvan64
Re: Spam autodetect
Mon Oct 15, 2007 12:58 pm
just use an email program like emailbomb and try it for yourself. See if you got banned from your own network :)
Cheers
Users browsing this forum: lixxdee, ramirez, sindy and 174 guests
