matt
LoRa to Home Assistant
Thu May 26, 2022 8:32 am
Hi Guys
I have a LoRa Gateway connected to The Things Network.
Using TTNV3, I have the Integration passing data to Home Assistant.
Does anyone know if you can directly configure LoRa to pass directly to Home Assistant, with out using The Things Stack on an internal network?
LoRa to MQTT?
Cheers
germarsh
Re: LoRa to Home Assistant
Sat Jun 25, 2022 6:13 pm
Please excuse my ignorance as I am new to MikroTik devices. Does the LoRa device use RouterOS or would that be too verbose for it?
There is a big push for such devices here in South Wales. I currently use Home Assistant for a few tasks but mainly monitoring a ground source heat pump via MQTT. Few other MQTT feeds as the broker runs on the Linux laptop running HA.
I am looking to use MQTT to get metrics from the router and 4G (LTE) modem.
germarsh
Tue Jul 05, 2022 11:12 pm
Home Assistant monitoring of modem and router...
denissMT
Thu Sep 08, 2022 11:30 am
Hi Guys
LoRa to MQTT?
Cheers
Currently, you can only send LoRa traffic to a LoRa server directly and you can not "push" it via MQTT yet.
vittore
Tue Mar 07, 2023 1:18 pm
Hi Guys
LoRa to MQTT?
Cheers
Any news?
I'm trying to use iot package https://help.mikrotik.com/docs/pages/vi ... d=63045633
v.
infabo
Long time Member
Long time Member
Tue Mar 07, 2023 10:11 pm
How did you achieve that?
Users browsing this forum: No registered users and 177 guests
