cptbill
cell lock on CHATEAU LTE12 - output error
Fri May 27, 2022 7:03 pm
Super newbie here.
I have been using for a year a CHATEAU LTE12 without problems. Excellent modem/
I have been running RouterOS v7.2.3 and LTE modem Model EG12-EA with fw EG12EAPAR01A11M4G
I want to lock my CHATEAU on the specific cells (see screenshot)
Primary Band B7@20Mhz earfcn: 3050 phy-cellid: 438
CA Band B3@20Mhz earfcn: 1700 phy-cellid: 438
When i enter the following command i get output error
interface/lte/at-chat lte1 input="at+qnwlock="common/4g",1,3050,438"
output: ERROR
When i type for example the following (which to be honest i have no idea what it does, it seems like a help command?) i do get a response
[admin@MikroTik] > interface/lte/at-chat lte1 input="at+qnwlock=\?" wait=yes
response:
output: +QNWLOCK: "common/4g",<num of cells>,[[<freq>,<pci>],...]
What am i doing wrong?
mkx
Re: cell lock on CHATEAU LTE12 - output error
Fri May 27, 2022 7:09 pm
I guess you have to escape the inner quotes:
/interface/lte/at-chat lte1 input="at+qnwlock=\"common/4g\",1,3050,438"
SiB
Fri May 27, 2022 11:36 pm
one additional info.
Cell Lock to 1 specific tower & "antenna"
/interface/lte/at-chat lte1 input="at+qnwlock=\"common/4g\",2,3050,438,1700,438"
/interface/lte/at-chat lte1 input="at+qnwlock=\"common/4g\",2,1700,438,3050,438"
Remember that order is not important and both command do the same. Module select one with best signal and that start to be primary-band. When you put more "CellLocks" then you not know with one it will be connected, the signal is a selector here.
You can select by Cell Lock the Primary band, but all other CA are automatically. Only limiting the active bands can do some help to select proper ca.
cptbill
Sat May 28, 2022 1:01 am
stupid me. Thanks a lot guys. Cell lock is successful now.
And SIB thanks for the extra info regarding carrier aggregation.
One more question. Is the cell lock still valid in case of a reboot on the CHATEAU ?
SiB
Sat May 28, 2022 1:38 am
cptbill write
in 95% yes, check it becasue I not remember each lte module :)
Users browsing this forum: Bing [Bot], mansuramir and 100 guests
