Can this be accomplished?
would be vlan tags comming into a eoip tunnel interface be transported over the other end?
thanks
Gino
I have used option 2 for more than 6 months. It should be working.How can this be accomplished?
1. Bridge each VLAN to the EoIP tunnel at both ends? (this works with dedicated EoIP tunnels for each VLAN)
2. Bridge each Ethernet Port to the EoIP tunnel at both ends? (this is not working).
Please let us know if there is another option where this can be done using a single EoIP tunnel.
Thank you,
