Hi!
I have an IPsec site-to-site VPN between two MikroTik routers. It works and hosts on either end can communicate with each other (to the extent allowed by firewall rules). The problem is that it seems that traffic originating from the router itself (for example pinging from one router to a computer at the other end of the tunnel) is not sent via the IPsec tunnel. I found this thread: viewtopic.php?t=147819
I have tried some things suggested in this thread (an accept NAT rule for example), but to no avail and most things discussed in this thread is beyond my skill set or comprehension.
What I really want to accomplish here is to make the remote MikroTik router use a local NTP server and maybe also a local DNS server (Pi-Hole).
Can anyone shed some light on this in a non-expert friendly manner (i.e. using WinBox, not commands)?
Thanks a lot!
