ashwingorityala
Can anyone help me with a script which automatically kills all the connections at the specified time of the day?
Sun May 29, 2022 12:44 pm
Hello, I have four VPN services configured on my MikroTik router out of which three are L2TP and one is IPsec.
I face a problem with the IPsec VPN, as the VPN's public IP is dynamic (I use DDNS) and hosted on Fortigate Firewall, whenever there is a change in public IP I need to kill the connection so that the traffic passes.
DeJoe
Re: Can anyone help me with a script which automatically kills all the connections at the specified time of the day?
Mon May 30, 2022 12:42 am
Hi.
If I understand you correctly you just have to write a one-line script that just contains:
/ip/ipsec/active-peers/kill-connections
Just use the sceduler to either run that code directly or to run a script that contains it.
It should be enough.
rextended
Re: Can anyone help me with a script which automatically kills all the connections at the specified time of the day?  [SOLVED]
Mon May 30, 2022 1:28 am
Probably RouterOS 6.x
/ip ipsec active-peers kill-connections
Users browsing this forum: caminskibr and 26 guests
