clinttt
Load Balancing [HELP]
Mon May 30, 2022 7:11 pm
Hello guys good day. i have a small problem with my configuration i have i have 2 ISP witch has 500MBPS both and i have configured it in PCC Method
below is my configuration..my problem is that every time i run a speed test it only gives me 100MB..
/ip firewall mangle
add action=accept chain=prerouting comment="ACCEPT IP ADDRESSES" \
dst-address-list=myip
add action=mark-connection chain=input comment="Marking ISP" in-interface=\
"ether1-ISP1" new-connection-mark=ISP1 passthrough=yes
add action=mark-connection chain=input in-interface="ether2-ISP2" \
new-connection-mark=ISP2 passthrough=yes
add action=mark-connection chain=prerouting comment="LOCAL PCC" \
connection-mark=no-mark dst-address-type=!local in-interface-list=LAN \
new-connection-mark=ISP2 passthrough=yes per-connection-classifier=\
both-addresses:2/0
add action=mark-connection chain=prerouting connection-mark=no-mark \
dst-address-type=!local in-interface-list=LAN new-connection-mark=ISP1 \
passthrough=yes per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting comment="marking conn" \
connection-mark=ISP1 in-interface-list=LAN new-routing-mark=to-WAN1 \
passthrough=yes
add action=mark-routing chain=prerouting connection-mark=ISP2 \
in-interface-list=LAN new-routing-mark=to-WAN2 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=ISP3 disabled=yes \
in-interface-list=LAN new-routing-mark=to-WAN3 passthrough=yes
add action=mark-routing chain=output comment=output connection-mark=ISP1 \
new-routing-mark=to-WAN1 passthrough=yes
add action=mark-routing chain=output connection-mark=ISP2 new-routing-mark=\
add action=mark-routing chain=output connection-mark=ISP3 disabled=yes \
add check-gateway=ping comment=ISP1_TAB disabled=no distance=1 dst-address=\
0.0.0.0/0 gateway=192.168.254.254 pref-src="" routing-table=to-WAN2 \
scope=30 suppress-hw-offload=no target-scope=10"
add check-gateway=ping comment=ISP2_TAB disabled=no distance=1 dst-address=\
0.0.0.0/0 gateway=192.168.1.1 pref-src="" routing-table=to-WAN1 scope=30 \
add comment=ISP1 disabled=no distance=2 dst-address=0.0.0.0/0 gateway=\
192.168.1.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=\
no target-scope=10
add comment=ISP2 disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
192.168.254.254 pref-src="" routing-table=main scope=30 \
ingdaka
Trainer
Trainer
Re: Load Balancing [HELP]
Mon May 30, 2022 7:54 pm
You should check when you have to many connections running. Speed test will create a connection from your computer to 1 server. PCC - Per Connection Classifier, so if you have 1 connection it will go only from 1 ISP.
BrianRS
Mon May 30, 2022 8:24 pm
I have a similar setup, but I seem to have lost the feature of combined download bandwidth, however the upload remains.
So I have a WAN1 via 3rd party DSL modem and a WAN2 via 3rd party 4G router.
I used to be able to go on speedtest.net and whilst testing I was looking a the traffic graph for both WAN interfaces and I could see them maxed out on both download and upload.
Now it seems this is no longer applicable for download ONLY after a reboot/update?
The only thing I done since last time I tested was to add a mangle rule to force a specific LAN client (172.16.11.41) constantly on the same WAN (DSL) and some tinkering with the oVPN address and profile.
Any views, please?
Here's my config, relevant to this topic:
# may/30/2022 18:09:23 by RouterOS 6.49
# software id = SJ6W-GLAW
# model = 850Gx2
# serial number = 4BF104******
add arp=proxy-arp name=BRIDGE
set [ find default-name=ether1 ] name="eth1 - LAN (PC)"
set [ find default-name=ether2 ] name="eth2 - LAN (LACP1)"
set [ find default-name=ether3 ] name="eth3 - LAN (LACP2)"
set [ find default-name=ether4 ] name="eth4 - WAN1 (DSL)"
set [ find default-name=ether5 ] name="eth5 - WAN2 (4G)"
/interface pppoe-client
add disabled=no interface="eth4 - WAN1 (DSL)" name="PPPoE - ZEN" password=************ user=************
/interface bonding
add lacp-rate=1sec mode=802.3ad name="LACP 2 C2960X" slaves="eth2 - LAN (LACP1),eth3 - LAN (LACP2)" transmit-hash-policy=layer-2-and-3
add name=oVPN-pool ranges=192.168.11.2-192.168.11.254
/ppp profile
add local-address=192.168.11.1 name="Brian ovpn" remote-address=oVPN-pool
add bridge=BRIDGE interface="eth1 - LAN (PC)"
add bridge=BRIDGE interface="LACP 2 C2960X"
/interface ovpn-server server
set auth=sha1 certificate=server cipher=aes256 enabled=yes netmask=23 require-client-certificate=yes
add address=192.168.88.1/24 disabled=yes interface="eth1 - LAN (PC)" network=192.168.88.0
add address=172.16.11.1/23 interface=BRIDGE network=172.16.10.0
add address=10.1.1.2/28 interface="eth5 - WAN2 (4G)" network=10.1.1.0
set servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=172.16.10.0/24 list="INet subnet block"
add address=172.16.11.41 list=IntelNUC
add action=drop chain=forward comment="INet subnet block" src-address-list="INet subnet block"
/ip firewall mangle
add action=accept chain=prerouting dst-address=*public-IP* in-interface=BRIDGE
add action=accept chain=prerouting dst-address=10.1.1.0/28 in-interface=BRIDGE
add action=mark-connection chain=prerouting in-interface=BRIDGE new-connection-mark=WAN01 passthrough=yes src-address=172.16.11.41
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface="PPPoE - ZEN" new-connection-mark=WAN01 passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface="eth5 - WAN2 (4G)" new-connection-mark=WAN02 passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=BRIDGE new-connection-mark=WAN01 passthrough=yes per-connection-classifier=both-addresses-and-ports:2/0
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=BRIDGE new-connection-mark=WAN02 passthrough=yes per-connection-classifier=both-addresses-and-ports:2/1
add action=mark-routing chain=prerouting connection-mark=WAN01 in-interface=BRIDGE new-routing-mark=to_WAN01 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN02 in-interface=BRIDGE new-routing-mark=to_WAN02 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN01 new-routing-mark=to_WAN01 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN02 new-routing-mark=to_WAN02 passthrough=yes
add action=masquerade chain=srcnat out-interface="PPPoE - ZEN"
add action=masquerade chain=srcnat out-interface="eth5 - WAN2 (4G)"
add action=masquerade chain=srcnat comment="oVPN NAT" log=yes src-address=192.168.11.0/24
/ip firewall service-port
set ftp disabled=yes
set irc disabled=yes
add check-gateway=ping distance=1 gateway="PPPoE - ZEN" routing-mark=to_WAN01 scope=255
add check-gateway=ping distance=1 gateway=10.1.1.1 routing-mark=to_WAN02 scope=255
add check-gateway=ping comment="Primary gateway" distance=1 gateway="PPPoE - ZEN" scope=255
add check-gateway=ping comment="Seconary gateway" distance=2 gateway=10.1.1.1 scope=255
/ppp secret
add name=*user* password=************ profile="Brian ovpn" service=ovpn
/system clock
set time-zone-name=Europe/London
/system ntp client
set enabled=yes primary-ntp=162.159.200.123 server-dns-names=uk.pool.ntp.org,pool.ntp.org
msatter
Mon May 30, 2022 8:42 pm
Beter make this both-addresses:2/0 and both-addresses:2/1 also include the dst-port and src-port. Then both ISP being used is more likely and also check if you have enabled fasttracking also.
Ingdaka is also refering to plitting the connections.
BrianRS
Mon May 30, 2022 9:11 pm
thanks @msatter for the prompt response.
I have applied your change and it actually didn't have the desired result, in fact the Upload was no longer benefiting from the merged bandwidth either.
However I reverted the change back to both-addresses-and-ports:2/0 and both-addresses-and-ports:2/1 and now the download is working as expected, where it is merging bandwidth from both WANs.
Regarding Fasttracking, I'm not sure about it, not used it before, can it be implemented at this stage?
anav
Mon May 30, 2022 10:26 pm
"plitting", sounds like some deviant sex terminology msatter ;-PP
clinttt
Tue May 31, 2022 5:36 am
Hi sir I just have a handful of connections running I just used /28 for my route to OSPF in 2 ports for DHCP port ROUTE and DHCP and group in Interface LIST which is the LAN on the configuration
clinttt
Tue May 31, 2022 5:40 am
Any views, please?
# model = 850Gx2
/interface bonding
/ppp profile
/ip firewall mangle
/ppp secret
/system clock
/system ntp client
Hi, sir thnx for the response... have you tried on testing to change the Per Connection Classifier
clinttt
Tue May 31, 2022 5:42 am
Hi, Sir thnx for the response. Well, I have checked the configuration but I haven't tried the Fastrack for Both ISP. does it need to be fast track
sindy
Tue May 31, 2022 7:55 am
@clinttt, let's start from the basics - without any load balancing configuration, and with the action=fasttrack-connection rule disabled in /ip firewall filter, does your router manage the 500 Mbit/s over the primary WAN? You haven't shown what router model you have, and 500 Mbit/s throughput is far beyond the capabilities of many SOHO models, let alone the full 1 Gbit/s.
@msatter, did you indeed mean to enable fasttracking? Since any kind of load distribution except the ECMP one depends on mangle, you can not permit fasttracking for all the traffic, at best it can be permitted for traffic going through one of the WANs.
clinttt
Tue May 31, 2022 8:18 am
hi sir @sindy thanx for the response. Well with regards to direct speed of the ISP we've tried several Test like Direct speed test from Modem to PC and speed test from MT to PC. and yes we have reach the said speed test with 500mbps per modem. by the way we are using RB5009 as our CORE Router. So far we are not encountering problems yet since we just have a handful of clients as of this moment. we are just preparing just for the worst. and also I don't have fasttrack in my Filter Rules
sindy
Tue May 31, 2022 8:40 am
For a 5009, two 500 Mbit/s uplinks should not be an issue even with mangling. As you don't use fasttracking, and as hardware-offloaded routing cannot interfere with mangle because it is not supported on RB5009, the speed limitation cannot be caused by some packets to bypass mangling and end up on the wrong WAN.
Are the mangle rules you've shown the only ones you use? I can see nothing wrong about them alone, nor about the routes, everything is as it should be for a 1:1 load distribution.
While running the speedtests, could you watch the actual bandwidth occupation on the WANs (/interface/monitor-traffic etherX,etherY)?
clinttt
Tue May 31, 2022 9:07 am
This is the images that I set
Filter Rules = I put this because to not let my client access my isp MODEM or allow then to tracerrout
NAT Rule
Mangle Rules
Interface
ISP Port Traffic
sindy
Tue May 31, 2022 9:20 am
Well, the order of the mangle rules could be optimized a little bit, but that still doesn't explain the throughput limitation. Anything configured in queues?
clinttt
Tue May 31, 2022 9:44 am
Thats why I am very confused right now and I don't have a queues. Well, there is one that I haven't tried. do I need to bridge mode the modem?
BrianRS
Tue May 31, 2022 9:50 am
This is really confusing now....
...so I noticed something interesting... if I test speed via Ookla (speedtest.net) I seem to be utilising both WANs on upload and download, but I also noticed whilst one of the LAN clients was downloading a big update file this was coming down only on WAN1, so no combined bandwidth. See the attached graphs for the client updating and the speedtest...
clinttt
Tue May 31, 2022 10:00 am
Maybe your trying to combine the speed...because load balancing it just trying to split the traffic. my case is different to yours because I have set the firewall but I cant get the speed test correctly.
can you post your script so that we can exchange idea?
sindy
Tue May 31, 2022 10:52 am
If the modem itself can deal with the 500 Mbit/s, there is no point in moving the PPPoE client processing from the modem to the 5009, unless the modem has a public IP address on it and you want to use that address directly on the 5009. Otherwise, running the PPPoE client(s) on the 5009 would just add more load to the CPU and bring no benefits.
Sorry, from your description of the tests "without load distribution" it wasnt' completely clear to me what exactly you did. So let's put it another way, what is the result of the speedtest if you test the same way like you do with load distribution, but with all the mangle rules in chain prerouting disabled? This will tell us whether the mangle rules or something else is the reason of the low speed, as the hardware topology will be the same for both scenarios (with and without load distribution).
msatter
Tue May 31, 2022 11:06 am
snip.....
I didn't know which router was used having low speeds, is often due to not enabling fasttracking on slower routers. Enabling it on a pure routing config, indeed it- breaks the traffic flow. That why I first always connection-mark and then based on that mark, set the routing-mark. This to be able to also re-mark the correct routing-mark for later traffic coming back from the clients.
General warning, not all dst-addresses support multiple connections. This forum, for example does not support that. You can test that when you write a posting and press preview and nothing happen or with a delay.
msatter
Tue May 31, 2022 11:12 am
That is the correct working. You have one target and the client uses one connection.
When the client and the server support concurrent connections, then the downloaded file is split in parts and downloaded parallel. Look for IDM which does that for you,
https://www.internetdownloadmanager.com
clinttt
Tue May 31, 2022 12:43 pm
Hi sir haven't tried disabling my mangles..with regards with PPoE clients...my current Concentrator is separated from my CORE
sindy
Tue May 31, 2022 12:53 pm
I was talking about the uplink side, i.e. about the modems connecting you to the upstream ISPs - as you've mentioned putting modems to bridge mode, I've assumed that's what you were talking about too. Was it a misunderstanding?
clinttt
Wed Jun 01, 2022 1:20 am
hi Sir, yes I was thinking maybe i should put my modem to bridge mode...
ErkDog
Thu Jun 02, 2022 6:29 pm
It looks like you are trying to achieve the results of "Channel Bonding" which you can't do with standard Mikrotik methodologies.
Load Balancing and Channel Bonding are different.
Load Balancing, takes any new outgoing connections and routes them over the least used interface.
The reason you are seeing faster results on speedtest.net is because it supports MULTIPLE connections during the speed test, so your Load Balancing is working as designed.
It's equivalent to "Single Threaded" versus "Multi Threaded" applications.
99% of internet traffic is "Single Threaded" meaning it will only go over one or the other of your WAN connections at any given time. The benefit of Load Balancing, is that if someone is downloading a large file on Connection A, and someone else starts a large download it will go over connection B, giving you "combined" bandwidth, in general.
To truly achieve "Bandwidth aggregation" it requires SD-WAN that supports "Channel Bonding". Or you can set something like that up yourself, but it requires a VPS/Server in a data center to establish the tunnels to.
sindy
Thu Jun 02, 2022 6:36 pm
The only thing I disagree with in what you wrote is that load balancing is capable to identify the least used interface.
But the OP's problem not that a single session is unable to use the aggregated bandwidth of both WANs (which is indeed the most frequent question related to load balancing here on the forum). The OP's problem is that the test shows just a fraction of the bandwidth of a single WAN.
BrianRS
Fri Jul 01, 2022 2:48 pm
Thank you ErkDog & sindy & msatter for your inputs, I now understand and agree with all your conclusions.
And I'm also happy the device is performing as it should.
Much appreciated,
B
BrianRS
Mon Jul 04, 2022 1:10 pm
Thank you once again ErkDog for your reply.
I had a little look into "Bandwidth aggregation" using VPS and oVPN.
I'm currently using Channel Bonding between my MikroTik router and a C2960X, so I'm familiar with the concept, however, achieving this in "the cloud" is a bit of a news to me.
Do you have any documentation you can point me towards, to achieve this using the RB850Gx2 I have, maybe?
Many thanks,
B
Users browsing this forum: Bing [Bot], kosyot and 100 guests
