Spoonsy1480
netinstall hap ac2
Mon May 30, 2022 11:16 pm
i have been trying to get my hap ac2 to work with a lot of problems im now trying to do a netinstall and it never shows my device in the window. using a windows laptop tried lan port and wan port nothing held rest for 20 seconds nothing
holvoetn
Re: netinstall hap ac2
Mon May 30, 2022 11:27 pm
Disable all network ports on that laptop, including wifi.
Only keep ethernet active.
Using a dumb switch in between might help.
Spoonsy1480
Mon May 30, 2022 11:46 pm
I did disable all ports and Wi-Fi, I will try a dumb switch. What does the dumb switch do?
anav
Tue May 31, 2022 4:13 am
Read the section in PARA H here - viewtopic.php?t=182373
chechito
Tue May 31, 2022 5:00 am
dumb switch avoid your laptop ethernet interface relink every time you try reboot/netinstall on your mikrotik, in some cases is the only way to get netinstall to work
holvoetn
Tue May 31, 2022 6:14 am
For me the only way to get it to work lately, is using a Linux box.
Might be another option.
Users browsing this forum: PBondurant, valeb and 52 guests
